P170HM - Blank Screen During POST
Discussion in 'Sager and Clevo' started by zacpack, Sep 7, 2018.
  1. zacpack
    zacpack Newbie
    Hi
    I have a Clevo P375SM-A and the laptop screen does not work during the POST/BIOS screen unless an external monitor is connected, once the laptop is booted into Windows it works perfectly fine and both Laptop and external monitors work.
    Has anyone got any clues on how to make the Laptop screen work during POST/BIOS?
    Many Thanks,
  2. Prostar Computer
    Do you happen to know which BIOS version you're on? And which version of Windows?
  3. Meaker@Sager
    Have you replaced the GPU?
  4. zacpack
    zacpack Newbie
  5. Danishblunt
    Danishblunt Notebook Prophet
    remove BIOS battery and reset EC, then try again. It's certainly a weird issue you're having.
  6. zacpack
    zacpack Newbie
    Thanks - how do I reset the EC?
  7. Meaker@Sager
    By removing ac and main system battery. The bios battery would reset the CMOS (bios) as well and you would have done a bios + EC reset.
  8. zacpack
    zacpack Newbie
    Thanks, first things first, I mentioned the wrong Clevo machine, I have a P375SM-A. I've corrected the main message but unable to correct the title.
    Secondly, I've removed the battery and CMOS battery for at least 2 hours and reconnected them both, still no change. The laptop display does not work in POST only when it gets to Windows does it work.
    So in order for me to access any BIOS settings I have to connect an external monitor.
    I think it probably needs a new graphics card, any recommendations for where to get it one?
  9. Meaker@Sager
    It's more likely a vbios issue. However with a bit of modding of the cooler the GTX 1060 performs pretty well.
  10. zacpack
    zacpack Newbie
    Thanks - the current vbios is as attached. Know how to re-flash / update it?
