P170EM GPU temp not displayed
Discussion in 'Sager and Clevo' started by JAGMAN, May 26, 2019.
  1. JAGMAN
    JAGMAN Notebook Geek
    hi,
    my gpu temp as well any info of the gpu are nowhere to be found on HWmonitor or on similar programs only the integrated is displayed.I have a 7970m , back when i got it i remember that there was then a driver issue that you needed to install first the clevo driver and afterward the updates otherwise bsod was welcoming you:rolleyes:,when i istalled windows again (its been a couple of years:p)gpu info was lost, i installed then the latest driver from AMD and i have been doing so ever since.
  2. Meaker@Sager
    The gpu is off when not in use, use the GPUz load generator and start the program again.
    Or is the GPU not showing in device manager?
