P157SM heavily modded speakersystem
Discussion in 'Sager and Clevo' started by Danishblunt, Jan 9, 2018.
  1. Danishblunt
    Danishblunt Guest
    Just no, you should know how subwoofer and loudspeakers work. I did this experiment with the enclosure as well and the subwoofers do get signiticantly better the bigger the enclosure to a point. Too small boxes will dimish the bass significantly. The type of the enclosure also matters for the subwoofer as well, open or closed for instance.
    No, the subwoofer of any MSI system I've owned never bottomed out. The only way to bottom out a subwoofer is to boost low frequencies to the point where the sub can't handle it, thanks to barely putting power into speakers, I dare say it's impossible to bottom out an MSI sub on a clevo system for instance.
  2. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    It is 100% possible and I will prove it to you in my next mod which I will upload to a thread here. They bottom out quite easily, on about 50% volume for my clevo. Yes you are right adding gain to lower frequencies causes this effect too.
  3. Danishblunt
    Danishblunt Guest
    When is the next mod ETA?
  4. DaMafiaGamer
    Roughly in 2 weeks time
  5. Danishblunt
    Danishblunt Guest
    Perfect, looking forward to your proof and mod. What model is it going to be btw? (sub and notebook)
  6. DaMafiaGamer
    Either a clevo P870dm-g or eurocom tornado f5
    It's going to be the gt70 subwoofer unless there is no space for it to physically fit, then I will use the gt72 subwoofer.
  7. Danishblunt
    Danishblunt Guest
    Pretty sure you mean the other way around, since the GT 72 sub is bigger than the older revisions.
  8. DaMafiaGamer
    We will see, I'll post all the steps on a thread. I will start as soon as I get the parts and finish the coffee lake mod I'm doing atm, thanks for the info on the gtx 1070 though I appreciate it.
    sicily428 likes this.
  9. Moeness
    Moeness Notebook Enthusiast
    Hey there folks. After all was discussed, can someone please point to a tutorial or a how to on the drivers part? Thanks.
