P150EM Brightness not changing
Discussion in 'Sager and Clevo' started by viper8548, Dec 19, 2012.
  1. viper8548
    viper8548 Notebook Guru
    Hey guys I have a P150EM with a 7970M I can't seem to change brightness of my screen,
    Fn + F8 and F9 brings up the on screen display but the value doesn't change at all. Its always on max.
    The brightness bar in Power Options is also missing, I think this happened since I installed Catalyst 12.11 Beta3, just tried upgrading to beta 11 and same problem. anyone have similar issues or solutions?
  2. kong
    kong Notebook Consultant
    Tried updating the Intel Graphics driver?
  3. viper8548
    Just updated to latest Intel Graphics Driver, same problem, I'm going blind at the highest setting in the dark :(
  4. viper8548
    Finally fixed it, for those who may run into this problem the solution is here:
    Can't adjust display brightness - Page 2
    Anyone still unable to solve the problem try the following:
    Start > Control Panel > Hardware and Sound > Device Manager
    Once the Device Manger box opens expand the "Monitors" tab
    Left Click and Uninstall the monitor listed
    Then select the Scan for Hardware Changes Icon
    Sounds bizarre, but the adjust display brightness should reappear.
    codral likes this.
  5. kong
    Glad you sorted it out :)
  6. MrDJ
    MrDJ Notebook Nobel Laureate
    thanks for posting the solution for others. +rep
    just wish more people that come here for advice would do this and not just dissapear after.
  7. Prostar Computer
    Did this resolve being able to adjust the brightness setting on the OSD using the FN keys? Or did it bring back your brightness control in Windows display settings?
  8. viper8548
    Both, the OSD was always showing up, but the values wont change whether I try to increase or decrease the brightness. The fix fixed both changing brightness via GN Keys and Windows display settings/Power options
  9. nailep
    nailep Notebook Enthusiast
    Is your OS win 8? If yes, please use 12.8 driver
  10. Prostar Computer
    Ah, very interesting that it fixed both. Thanks for the update! I know there were a few Asus users than ran into an identical issue.
