p150em backspace key problem + FN key swap
Discussion in 'Sager and Clevo' started by wingman4ever, Jun 20, 2012.
  1. wingman4ever
    wingman4ever Notebook Consultant
    Hi,
    My p150em backspace doesn't register that well. When I tap at the left part of the backspace key or the righter part it doesn't work. It only works if i press at the middle part. the spacebar and enter key works great though.
    So my question is do other p150em users have this issue too?
    And is there an easy fix for this?
    Also I would like to know if it's possible too swap the FN key with the windows key? I alreay tried several key remap tools like sharpkeys, keyTweak and MapKeyboard. But they all don't support the FN key.
    Thanks in advance..
  2. Rudlin
    Rudlin Notebook Consultant
    Hi, Ive had the same issue with TAB button and its still giving me headaches what I did was taping quickly and then firmly depressing button for a minute and repeating a couple of times and looks like it helped so far.
  3. wingman4ever
    @Rudlin Weird it actually worked still not perfect but much much better thanks!
  4. Rudlin
    Hey im glad it worked its 100% out of blue method that i just came up with and itdid helped me too aswell
  5. flyingnugget
    flyingnugget Notebook Enthusiast
    My space key doesnt register when I press on the edge of they key. Its annoying because for years I have typed and always pressed on the edge of they key. Now I have to retrain my brain to move my thumb onto the middle of the key.
  6. Stevenbrz
    Stevenbrz Notebook Enthusiast
    Do you guys with the key registering problem all have the stock Sager keyboard because I will definitely get the SteelSeries keyboard if the stock one has problems. Anyways, good luck fixing your problem.
  7. wingman4ever
    Yes we have the stock one.
    Although the backspace key works much better now, it still doesn't register 25% of the times. So I may replace it with the SteelSeries one in the future too bad I like the look of this keyboard more...
