P-7811 PCpitstop issues
Discussion in 'Gateway and eMachines' started by Eric618, Mar 15, 2009.
  1. Eric618
    Eric618 Notebook Consultant
    Hey guys,
    In running PC Pitstop on my system, I'm consistently getting results saying memory performance and 2D video are very poor. What could be causing either of these? I have the most recent laptopvideo2go video driver, and I am always using less than 30% of available physical memory. It's frustrating.
    Any ideas? I'm running XP Pro x86 SP3.
  2. E-wrecked
    E-wrecked BANNED
    The problem is that you're running PC Pitstop on your system. :D
  3. JohnWhoTwo
    JohnWhoTwo Notebook Deity
    You know, I believe E-wrecked has correctly identified the problem.
  4. JohnWhoTwo
  5. TANWare
    Just ran mine it was fine, they say visual effects is sub optimal because the effects use up preformance, now come on..................
  6. Eric618
    LOL! :D I use it not for an overall benchmark, but for comparison among systems I've had/have. On the 7811 is the first time I've had memory or video warnings.
  7. TANWare
    I had no memory warnings, I did have the "sub optimal Video" but it said I had too many video effects enabled and this can affect performance. Jees, all I do is desktop work so yes, enable that eye candy please............
  8. Eric618
    It's odd, I scrapped the laptopvideo2go Nvidia driver, and installed the most recent stock one from Nvidia's site. Now, the memory issue is gone (posting good results now), but it's still reporting sub-standard 2D video performance. 3D video results stayed approximately the same. :confused:
