P-6860FX motherboard replacement
Discussion in 'Gateway and eMachines' started by jd254, Nov 20, 2009.
  1. jd254
    jd254 Notebook Enthusiast
    I need to replace my motherboard. Where can I get one? Also, how removable is CPU and GPU? If soldering is required, I'm going to need to pay someone.
  2. teksurv
    teksurv Notebook Guru
    GPU is soldered to the motherboard, so replacement should already have it. CPU is socketed and easily replaceable. Where to get one? i don't know. I'd start with Google.
  3. jd254
    can i use a different model's motherboard? im having a hard time locating my model's
  4. SwiftSnipeR
    SwiftSnipeR Notebook Consultant
    Im prety sure any gateway fx mobo will work BUT as far as the sockets changing sence the P-6831 i have no idea the newer gateways use DDR3
  5. Lykhan
    Lykhan Notebook Consultant
    Your best option would be just to send it in for repair.....
  6. jd254
    actually my best option would be to do it myself since it would cost me the least with the same result.
  7. stephen0205
    stephen0205 Notebook Consultant
    true, so how do u know its the motherboard, what was the pc doing ???
    also the cpu is reovable, the gpu is already on the mobo, to get the cpu out u untickten a screw, and lift it out.
    replacement borads and cpus are easily found new and used on ebay
  8. jd254
    laptop's problem: I press the power button, the media bar lights turn on, the hard drive spin, the fan doesn't spin, and I get no video.
    I have no idea where to buy the motherboard. I emailed so many ppl.
  9. mohjarr
    mohjarr Notebook Enthusiast
