Overclocking the Aorus X9 DT V8 w/ i9-8950HK TO THE MAX!
Discussion in 'Gigabyte and Aorus' started by GizmoSlip, Jul 2, 2018.
  1. GizmoSlip
    GizmoSlip Notebook Deity
    Hum... Looking more into it, I think you could be right. What score do you normally get when you set your 8700k to 4.4 ghz? The core clocks are showing stable at 4.4 ghz in Cinebench at least with HWMonitor and Intel XTU. Maybe my windows isn't nearly as optimized as yours or maybe errors are being thrown that I can look into. Papusan you're more experienced, so I'm open to your advise here.
  2. GizmoSlip
    I went back and tested the CPU Physics score for 3D Mark again, and I must not have been OCing the CPU during the test or something else weird was happening. I just got 18,713 when I ran it again. I can upload a picture if you'd like.
    Papusan and undervolter0x0309 like this.
  3. GizmoSlip
    I think Aorus leaves the 8850H with more unlocked settings than most, but the 8950HK can go above and beyond 4.4 ghz. Also, typically the 8950HK will come with a larger power brink and thicker chassis for better cooling, but from my experience with the Aorus X9 the realistic performance difference is that I would run the 8950HK at 4.5 GHz, and the 8850H at 4.3 GHz.
    Total power limit is also being raised a tad on the 8950HK to around 108W, while the 8850H topped out at 102W. At least in these two machines.
    undervolter0x0309 likes this.
  4. g85222456
    g85222456 Company Representative
    something interesting is the definition of 8850H given by Intel
    it's the first time they break the naming rule of overclocking model (no K attached) and we asked them why doing so & how to differentiate it with K-SKU, they didn't explain why there's 8850H with overclocking but they hinted the capability of OC on 8850H will be restricted.......
  5. JCordero31
    JCordero31 Notebook Consultant
    i think the 8850h is a 8950hk just down clocked and with less cache. They are 8950hks that didnt make the cut to handle the specs of it. Thats why the oc is limited and topped at 102 watts
  6. aaronne
    aaronne Notebook Evangelist
    ..edit..
    wrong thread sorry
  7. Papusan
    Thanks for the reply.
    No need for pict. But with what oc'd clock speed? 4.2GHz? Because the Physics score you post here is below what you should expect from 4.3GHz all 6 cores. And way too low for 4.4GHz. Thanks
    Edit.
    And all those 3DM Fire strike Physics results showed here is crippled if it's run with 4.3GHz overclock on all cores https://www.3dmark.com/compare/fs/15988166/fs/15988181/fs/15988233#
    Falkentyne likes this.
  8. rogeruzun
    rogeruzun Notebook Enthusiast
    Any advice for how to get performance out of an 8950HK in a thinner chassis that is more thermal limited than the Aorus? Can I just undervolt using XTU to levels of something like -0.050V to get it to thermal throttle less and maintain stability? I have a Eurocom Q8 and it thermal throttles fairly easily. What is the best advice for someone who owns one, does not want to sell it, and wants to get the most performance but not sacrifice stability. It is primarily used for video editing using Adobe Premiere Pro but I also play games on it.
    When the CPU is thermal throttling will it ever drop below its base frequency of 2.9 GHZ? I'd like to think that there is some advantage to the 8950HK compared to the 8750H even in a thin chassis that cannot cool it sufficiently.
  9. JCordero31
    Should have went with a Aorus X7 V8....better cooler. I was able to undervolt my 8850H to 0.160mv (stay at 63C on full Load)you shoud be able to do at least 0.120mv but every computer is different... Did you put LM? (Liquid Metal) if not i suggest a repaste. Also you should underclock it to 4.5ghz boost the 300mhz you wont lose much fps maybe 1 or 2 in games plus it may help with stablizing speed on just boost and undervolt. Use XTU. Make sure you dont have command and control app as it doesnt let xtu profile load on windows start up. I get 4.3 stable on mine but i underclocked to 4.1 to get cooler results. when i game i boost it to 4.4 but then it heats up to 70C
  10. undervolter0x0309
    undervolter0x0309 Notebook Consultant
    I would consider adding heatpipes on your heatsink if you have the time.
    https://www.ebay.com/itm/Copper-Hea...hIAAOSw9GhYZABv:sc:USPSFirstClass!98052!US!-1
    Or just order a normal heatsink and remove them
    https://www.ebay.com/itm/4-Heatpipe...172660&hash=item41e97750c1:g:L70AAOSwuPlbaHMR
    you could also line up the all the hot surfaces with heatsinks
    https://www.ebay.com/sch/i.html?_fr...2.A0.H0.Xheatsink.TRS1&_nkw=heatsink&_sacat=0
    etc.
    Your chassis could stop you from doing this last steps, unless you want to carve out some holes.
    Other ideas, are copper plates, extra fans (power source though?).
    If you give up on mobility then open the thing and stick a pc heatsink or water cooling etc.
    I'm joking about the last part :p, since you can just get a cheaper pc with a 8600k with better specs.
    May the force be with you.
