Overclocking i9-10900K - X170KM-G
Discussion in 'Sager and Clevo' started by Cedr1k, Apr 7, 2021.
  1. Cedr1k
    Cedr1k Notebook Enthusiast
    Yeah, it's throttling hard and i don't think that repasting would solve this issue. Maybe setting fans at full speed from the beginning of stress test would solve the issue. But I can find any button for it.
  2. Papusan
    FN+1 to set max fans.
    BrightSmith likes this.
  3. Cedr1k
    Oh it works, thanks :D
  4. Cedr1k
    Do you guys know why I can't reach 4.9Ghz even if it's set to 4.9 in XTU?
    Those are settings during stress test and it seems like it is capped to 4.8 no matter what. Is it BIOS thing?
  5. BrightSmith
    BrightSmith Notebook Evangelist
    Uninstall XTU and try Throttlestop instead? Also, have you monitored with HWinfo64?
  6. Cedr1k
    Yeah I have checked this also with HWinfo. I will try to OC with Throttlestop, thanks for and advice. I have seen also that Power Options in windows can fix this. I have create new plan with High performance and during stress test it was 4.9Ghz but I don't know why during benchmark for example 3D Mark Time Spy it clocks down to 4.8Ghz again.
  7. BrightSmith
    Could be power or voltage limits? Nothing in HWinfo64?
  8. Meaker@Sager
    Could be secondary or tertiary power limits.
  9. Cedr1k
    It is solved. I have changed Intel Overclocking Thermal Velocity Boost to disable. I have reduced cache ratio to 3.7Ghz and it is stable during stress test on 5.0Ghz on all cores. It throttle a little during cinebench but I don't think I will reach those temps during playing games. I even was able to reach 5.1Ghz but it was throttle hard during stress test so I left it on 5.0Ghz.
    Benchmarks:
    https://www.3dmark.com/spy/19743092
    https://www.3dmark.com/spy/19744276
    https://www.3dmark.com/fs/25380678
  10. Meaker@Sager
    It might have been trying to push the low core count clocks way higher then.
