Overclocking 7700HQ and GTX1070
Discussion in 'MSI' started by Pedro69, Dec 6, 2017.
  1. Pedro69
    Pedro69 Notebook Evangelist
    @Papusan
    Like i said, the underlocks only happens when in gaming...with stress test never got a issue. I put a image of GPU-Z to show that i not lock the VDDC.
    Unhappy User likes this.
  2. unclewebb
    unclewebb ThrottleStop Author
    It looks like you need to adjust the Core Voltage Offset and set the Offset Prefix to (-) to use negative offset voltage. That should be the same as what ThrottleStop lets you adjust. Hope you do not brick anything. ThrottleStop is very forgiving if something goes wrong.
  3. Pedro69
    Thanks @unclewebb
    And about the cpu cache? I think that the name "Ring" or "Uncore" is one of them.
  4. unclewebb
    @Pedro69 - CPU Cache, Ring or Uncore are different names for the same voltage setting. Make an adjustment in the bios and then run HWiNFO or HWMonitor and see what under volts are reported.
    Vistar Shook likes this.
  5. Pedro69
    So like in TS i should put the same value on Core voltage offset and uncore right?
  6. Unhappy User
    Unhappy User Notebook Consultant
    Hi Pedro, were you able to fix this or understand why it happens?
  7. Pedro69
    @Unhappy User
    You have the same laptop?
    Well, even if im able to put 140mv(had one BSSOD with 150) undervolt on cpu directly in my bios, the problem still there...sometimes i get the issue "BD Prochot" while playing but the issue not happen in stress tests.
    The only way to prevent "BD Prochot" is disable the feature in BIOS or lock the VDDC to 0.8750 with MSI AfterBurner.
    I need find a Vbios that limits VDDC only or a way to not use MSI AfterBurner anytime that i use laptop....
    Till now, my problem was fixed with VDDC locked at 0.8750V....with this i not got anymore underlocks of 800MHz or 2700MHZ...
  8. Pedro69
  9. Pedro69
  10. Pedro69
    UPDATE
    I recieve a email from MSI saying that i have a problem in the laptop about BDProchot, motherboard, for some reason the pc need to be sent to poland for msi engineers...
    Its strange since with the lock on VDDC the problem disappear...
    Kevin@GenTechPC likes this.
