Overclocking 7700HQ and GTX1070
Discussion in 'MSI' started by Pedro69, Dec 6, 2017.
  1. Papusan
    You will only know CPU, PCH and GPU temp. Not for other important components as VRM's osv. OEM*s can put in whatever throttle triggers they want outside already mentioned hardware in their firmware. See also How Dell cripple performance
    Have you tested with this Aida64 test setup?
    Maleko48 and Vistar Shook like this.
  2. Pedro69
    Pedro69 Notebook Evangelist
    Thanks Papusan for your reply,
    When you say "they want outside already mentioned hardware in their firmware", you mean EC firmware? Bios also? Or both?
    Yes, i posted a pic with that setup
    http://forum.notebookreview.com/threads/overclocking-7700hq-and-gtx1070.811524/page-5#post-10655310
  3. Papusan
  4. Pedro69
    Finally i unlocked my Bios, and yes, unlocked myself.... @Falkentyne was right :notworthy:
    And not have the oportunity to check all the options but already checked this :biggrin:
    Vistar Shook, ole!!!, Vasudev and 2 others like this.
  5. BeastsForever.TheDragon
    BeastsForever.TheDragon Notebook Evangelist
    Is this true about clevo also?
    Does prema bios and vbios are also locked for gpu oc and overvolting?
  6. Danishblunt
    Danishblunt Guest
    Even a hardware programmer cannot really change the power limit and such, there is a dedicated chip that will limit regardless of the powerlimit you're setting. At least according to EVGA.
  7. Pedro69
    NEW UPDATE:radar:
    Im playing the evil within since 3 hours and i not have anymore a BD Prochot, i think that discover the main reason for that issue...
    With MSI AfterBurner i locked the voltage 0.8750 on GPU with a max of 1900Mhz on Core and with 2000Mhz in memory, with this i not have anymore a single underclock or BD Prochot on ThrottleStop.
    There is another way to lock the voltage on GPU without the MSI program?
    So many tests and the issue with BD Prochot was the ****ing GPU.....just to mention that i not have any overclock on GPU.
  8. Kevin@GenTechPC
    So you no longer having the issue? :)
    Vistar Shook likes this.
  9. Pedro69
    If i use the curve of MSI AfterBurner and lock the voltage to the value 0.8750V....I not have anymore underlocks like 800MHZ or 2.9Ghz or any BD Prochot in TS program.
    Just to mention that i still have the same stock core and memory core even with that VDDC on GPU.
  10. Pedro69
    What menu i should use and what values i need put to use a undervolt of 150mv on cpu?
    If im not wrong, now with unlocked menus im able to do all kind of things like in TS program right?[/quote]
