Overclock Geforce 8800m GTX
Discussion in 'Gaming (Software and Graphics Cards)' started by spradhan01, Oct 20, 2008.
  1. spradhan01
    spradhan01 Notebook Virtuoso
    Can anyone give my steps by steps to overclock Geforce 8800m GTX SLI in Xps M1730 with Riva tuner or any other software. I dont have any idea in it and am afraid to try it because if I am wrong then it gonna toast my gpu.
    My specs are Core2Dyo T9300 2.4 ghz
    Geforce 8800m gtx sli 1 gb
    4 gb ram 667 mhz
    17" 1920X1200
    Thanks
  2. Magnus72
    Magnus72 Notebook Virtuoso
    Ntune is the only thing that works and of course hardware flashing the clocks. But Ntune works great.
  3. kal360
    kal360 Notebook Consultant
    ntune still doesnt work for me ! :( even if i change the various clock speeds it keeps switching back to default
  4. spradhan01
    Plz give me step by step suggestion plz
  5. Voodoofreak
    Voodoofreak Notebook Deity
  6. spradhan01
    How much it is safe to overclock Geforce 8800m gtx?
    And what are the thing that I should keep in mind while doing this?
  7. deedeeman
    deedeeman Notebook Deity
    you know, i never figured out why ppl would even want to OC their graphics card, especially a card like the 8800m gtx.....
    i know i would never OC my card...because i prefer life/low temps over performance anyday
  8. Ennea
    Ennea wwwwww
    Well, plugged in, which is how you should be gaming for the majority of the time, life shouldn't matter. Only thing I would be worried about are the temperatures. It is still strong enough to run most new games on high, if not max, but I guess if you play on a high resolution and you're really hardcore about maxing it out then you might be interested. Overall, it's still a bit early to do so, so do it at your own risk.
  9. chesieofdarock
    chesieofdarock Notebook Deity
    Easiest way to overl**** that I would reccoment would be download this overclocking utility. http://www.evga.com/precision/ Its very simple. Just make sure youre drivers allow overl****ing and then just play with the sliders and find what gives the best results without screen flicker or artifacts. Also, just make sure your heat stays below 90 degrees celsious and you should be fine.
  10. Magnus72
    Yes there is actually quite a difference between stock 500/1250/800 and 625/1550/950 I can say that right away. 625/1550/950 are pretty safe clocks for the 8800m GTX SLI in M1730. I have actually pushed mine up to 640/1550/950 artifact free.
