OS X programs&general questions/advice needed.
Discussion in 'Apple and Mac OS X' started by jimmy-floyd, Mar 25, 2009.
  1. jimmy-floyd
    jimmy-floyd Notebook Evangelist
    1. Advise a downloader(on Vista pc i use Flashget and enjoy it), Speed Download is shareware+interface is not too friendly. some pals recomended:
    iGetter, Leech, Download Queue, Download Wizard, and Download Manager, but which one to choose, which is better ?
    2. Which application delete program would you suggest:
    а) AppZapper
    b) CleanApp
    c) AppDelete
    3. need a prog. for .RAR files ( not Stuffit, cos it has unfriendly interface for me, imho), which is better:
    Unrar X,
    Simply Rar
    UnArchiver
  2. Colton
    Colton Also Proudly American
    1. Leech is a pretty good one, and I'd recommend it.
    2. I use AppZapper, but AppDelete and AppZapper are pretty much the same thing with a different UI in terms of what it deletes. I use AppZapper because of the sound effects though... :D :p
    3. Unrarx is great! I love it, and it works fantastic. +1 for Unrarx for stability and functionality. ;)
  3. jimmy-floyd
    Colton,
    thanks for answers.
    also another one questions:
    1. what are the good alternatives for iPhoto? yep i need a photo viewer. heared about Picasa and Just Looking, any others?
    2. Do i need do perform a system cleanup (maybe there are even special programs for that ?) like in windows?
    3. i own a Late 06 white Macbook(2ghz c2d, Part.# MA700RS/A) with 1gb ram.
    i want to upgrade to 2gb ram(by the way - will i get gain of perfomance with 2gb ram ?)
    what type of Ram should i use
  4. Colton
    No problem Jimmy! :)
    1. Picasa is pretty good, but it's still getting there. I'd use Picasa if I didn't have iPhoto. ;)
    2. Yes and no. Yes you could every other month or so, just to clean out the cache's/browsing history etc., but not an all out system cleanup. But you don't really have to do that, as that's mainly a pre-cautionary step to keeping it cleaned up.
    3. You can use PC2-5300 DDR2 RAM (667MHz). That's the only type your computer will allow. ;) Well surely you're going to gain performance, but obviously not as much as 4GB. Your Macbook will only see 3GB of it, so I think it'll give a noticeable performance increase. ;)
  5. jimmy-floyd
    good, also concerning browsers :
    i use Firefox, but for Safari there is a great add-on called Glims - it automatically maximizes browsing window, is there any similar add-on for Firefox?
  6. Colton
    As far as I know, my FireFox automatically maximizes my browser window, and I haven't really made any changes to the settings. I prefer FF, but Safari is also going to be a great browser after 4 is officially released. ;)
  7. fan of laptop
    fan of laptop Notebook Evangelist
    I am not a huge fan of maximizing the browser window. what is the point of doing it? Safari can automatically fit the window by the content of the window.
    By the way, I am using a 17 inch macbook pro
  8. Colton
    You can change that by using the green button in the top left hand corner of your window if you'd like, or you could go in the preferences in FF to change it. ;) I use it because I can get more content without scrolling. :)
