Optx aw2310 monitor... 3d from m17x r3
Discussion in 'Alienware 17 and M17x' started by legrunt, Dec 5, 2011.
  1. legrunt
    legrunt Notebook Enthusiast
    Just got an optx aw2310 monitor. Supposed to b 3d capable, but for the life of me, can't figure out how to get 120hz refresh rate for 3d! Tried hdmi->dvi cable, hdmi->hdmi cable, even a mini-dp->dvi adaptor plus the original dvi cable that came with the monitor! Using the latest nvidia drivers, but still no luck. 120 and 3d on the laptop screen is fine though...
    Anyone got any thoughts or tips?
  2. Toledano
    Toledano Notebook Evangelist
    Connect your monitor to your laptop, then right click on the desktop, go to screen resolution, and you should see your monitor there. See if you can change the hz from there. I did it with my sony, but I'm not home right now, so I can't exactly give you a lot of help.
  3. legrunt
    Tried that, but can't get more than 60hz. Someone mentioned something about dual link dvi? But the machine does not have dvi, only vga, hdmi and mini dp....
  4. catacylsm
    catacylsm Notebook Prophet
    Could force profile with Powerstrip:
    At your own risk of course.
    EnTech Taiwan | Utilities | PowerStrip
    Have the display information picked up stored and try and force refresh rate, might work.
  5. zoolian982
    zoolian982 Notebook Deity
    You need an hdmi to I believe dual link dvi adapter.
  6. vic_doom69
    vic_doom69 Notebook Consultant
    i plan on using this setup as well in a couple of weeks and would like to know the exact cable/adapter needed if anyone knows. a link would be great as well.
  7. zoolian982
    Well, I "Know" you need the hdmi to dual dvi, something about each connector only being able to produce 60hz, hence the need for 2.
    Beyond that, i'm not sure how the drivers or 3D enabling would work on the OptX moniter.
