Optical Drive dual fan Mod
Discussion in 'Alienware 17 and M17x' started by True Debreuil, Sep 14, 2018.
  1. True Debreuil
    True Debreuil Notebook Consultant
    Has anyone had any experience using optical drive to hold fans? I'm thinking of getting one of these to put in the optical bay of my m17xr4
    2 fan optical bay - Could be modded to fit larger fans+ come with fan speed settings
    M2 Slot + Single fan
  2. TheReciever
    TheReciever D! For Dragon!
    Interesting product, the use cases would be limited but helpful for exhausting additional heat, intake models would likely be pointless unless its modded to account for that.
  3. Grant B Gibson
    Grant B Gibson Notebook Deity
    Looks cool, but what would it cool? It would effectivly be pulling a tiny stream of air away from the heatsinks, and that's even if the laptop's optical drive has any access to the main components, on my Clevo, it's a separate compartment
  4. True Debreuil
    i imagined if you used the intake version, it would cool the PCH and the back of the gpu + add more air into the laptop lowering overall ambient temp.
  5. Grant B Gibson
    It all depends on the laptop tbh
  6. TheReciever
    exhaust would be better in most cases, more universally applicable.
    The other trick would be to add a heat exchanger and connect one or two heatpipes to the laptops heat sources but take it from me if the exhaust is on the right side of the laptop and your right handed its annoying having heat dumped on your hand.
  7. True Debreuil
    Would this fit in an m17xr4 where the dvd slot is covered up do you think?
  8. TheReciever
    Im leaning towards probably not, but luckily for you the dimensions are included in the description so you can mock up a template and see for yourself.
