(old) laptop for business use
Discussion in 'What Notebook Should I Buy?' started by amazing-boy, Jul 25, 2016.
  1. amazing-boy
    amazing-boy Notebook Evangelist
    1) What is your budget?
    Very limited. Max 300 euro, considening mainly second hand/refurbished products.
    b. Ultraportable; 11" - 12" screen
    c. Thin and Light; 13" - 14" screen
    IT
    a. Like: Lenovo, HP, Dell
    b. Dislike: Acer
    YES
    Only business use and web/platform programming
    Both
    No
    At least 4 hours
    Irrilevant
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Dual boot win + linux
    Screen Specifics
    12)...
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy
    Build Quality and Design
    Very important, particularly for build quality and sturdiness.
    15)...
    16)...
    Notebook Components
    17)...
    18)...
  2. amazing-boy
    The choise has to be done among these:
    - HP 2570P
    - Dell E6230
    - Dell E6330
    All of these are equipped with a intel i5 of third generation.
    o_O
  3. Krowe
    Krowe Notebook Evangelist
    Either of the Dells are fine, we still have plenty of the Tri-Metal series running around, and they purr just fine.
  4. amazing-boy
    Also of HP 2570P can be simply upgraded to I7, eventually ?
    For which aspects would You go with Dell?
    Sent with black Moto E2 2015
  5. Krowe
    The Tri-Metal ones are built like tanks, which is something I like.
  6. amazing-boy
    Do You consider these Dell better built and sturdier than 2570P, that has a metal chassis?
    I'm guessing also E6430 but it seems to be a little too bulky...
  7. Krowe
    If I recall correctly, the HPs also had a metal build, they're all tanks, but Dell has better service in my area. We dropped HP because of subpar servicing (which doesn't apply in your case), not because theirs wasn't built solidly.
  8. amazing-boy
    The servicing in my case is not important.
    I consider sturdiness, keyboard quality, display and overall performance to be the key aspects for the selection.
