Ok I give up, please help me find a portable laptop! Thanks
Discussion in 'What Notebook Should I Buy?' started by lottdod_1999, Feb 21, 2015.
  1. lottdod_1999
    lottdod_1999 Notebook Evangelist
    Ok I have been searching for days, mainly eyeing Lenovo laptops but I can't find one I really like. I currently have a Dell Studio 1558 that is just TOO heavy (it's about 6 lbs I believe) and too unwieldy. But the biggest problem is that it overheats a LOT! So low heat is important to me. And it throttles, a LOT, so no throttling is #1. The battery also sucks so I am of course looking for good battery life.
    1) What is your budget?
    $1 to $700
    c. Thin and Light; 13" - 14" screen
    Preferably online where I won't have to pay tax (I'm in California)
    a. Like:
    b. Dislike: Dell, have had nothing but trouble with these. Samsung, have had nothing but trouble with all their products. Sony, I worked for Sony I know how bad their stuff is or was.
    Yes
    Writing in Word, internet with a LOT of tabs open, youtube, porn.
    Yes
    Maybe
    4+
    Either
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows 7 but I can just install it later.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read.Click here for Screen resolution information.
    I would prefer 1080p, if not then 1600x900. 768p would I suppose be ok if it was a 13.3" laptop.
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    Glossy preferable
    Build Quality and Design
    I don't like silver.
    SOON
    2-3 years
    Notebook Components
    32GB minimum
    It would be nice.
  2. picolino
    picolino Notebook Consultant
    Well, probably something with a spill-proof keyboard.
    I would look for a refurbished thinkpad maybe, like t430s.
  3. lottdod_1999
    They just had a refurb t440s on their outlet for 5something and I was going to check out and their site just failed to load ugh
  4. Bronsky
    Bronsky Wait and Hope.
    You have to stalk the outlet to get what you want. I don't think they have anything for you ATM but that could change in a minute. The T440s would be a great option. Make sure it has minimum HD+ resolution. X240 too small?
