Official Sony Vaio Fit multi-flip PC Owners' Thread
Discussion in 'VAIO / Sony Owners' Lounge Forum' started by big_boss, Oct 13, 2013.
  1. Sher the Love
    Sher the Love Notebook Enthusiast
    In comparison with other star ratings on Best Buy's website, these products are doing terrible. I do believe that you'll see many more negative responses within message boards due to people troubleshooting, but reviews (in my opinion) won't be quite as biased.
  2. jovialjoy
    jovialjoy Newbie
    I ordered.. 13 with 128gb, 8 GB ram, AC WiFi. Hope the fan sound is bearable...
    Sent from my Nexus 5 using Tapatalk
  3. fl0werstar
    fl0werstar Notebook Geek
    Thanks, worked like a charm! I'm still having issues with text and images displaying awfully in certain apps (settings messages for one), but I guess that's gonna get solved soon with a few updates.
  4. ChocolateCake
    ChocolateCake Notebook Geek
    Curious, but what problem/fix are you referring to?
  5. Franek
    Franek Notebook Enthusiast
    Today I received my 13A i5 model. First impression - very light and high quality finish.
    Second impression - fan is very quiet, almost unnoticeable... until it started to shutting down randomly and became very hot. I discovered that fan was not working ;) After little taping at the back it started spinning. First it was very annoying, but installing McAfee helped a lot, and now its little better but not ideal . Quick look at msconfig and task manager showed me tooons of bloatware, update managers, services etc. I think that after heavy cleaning battery life and fan work should be improved a lot.
    I'm not impressed with the screen, viewing angles are strange - it looks that backlight is changing with different angle, and I can see light leaks from bottom.
    KnielsenDK likes this.
  6. Lasse M
    Lasse M Notebook Enthusiast
    It seems that the thinkpad yoga is coming out - I have a pick up date of 21/11/13 i Denmark -so far reviews/comments are overall positive.
    So I will cancel my Flip 13.
  7. HoodCP
    HoodCP Notebook Enthusiast
    For anyone having WiFi issues, this is the advice I got from Sony;
    1. Disable the wireless LAN adapter power management:
    a. Press the on start button.
    b. In the search field, type device manager.
    c. Open device manager.
    d. Expand the network adapters group.
    e. Right click on the wireless LAN adapter, and then click properties.
    f. Click on power management tab.
    g. Disable the option “Allow windows to turn off this device to save power”
    h. Click OK
    i. Connect to the network and if it drops the connection, please move to the next step.
    2. Reinstall Wireless LAN:
    b. In the search field, type VAIO Care.
    c. Click on restore and recovery.
    d. Click on reinstall application or drivers.
    e. Put check mark next to Wireless LAN driver and click next.
    f. Restart the System.
    g. If the issue remains, please run windows system restore.
    3. System restore:
    It is a feature which provides the opportunity to revert the operating system to a previous state. This step will not affect your data as it will only undo changes to the operating system. Please follow the link below for further guidance.
    Tips and solutions
    4. Full system recovery:
    If the above steps did not resolve the issue, we recommend performing a system recovery. This will conclusively determine the source of the problem. Please follow the link below and read the instructions carefully for details of how to do this
    VAIO Care 6:
    Tips and solutions
    VAIO Care 7:
    Tips and solutions "
    I'm trying step 1 for now. Will keep an eye on whether the connection issues go away & also how much this drains the battery.
    I suspect it's not the complete answer, as I find the problem can be just not getting as good a signal as my phone (Samsung Note 2) - but from memory this may have been more of an issue when using the battery, so let's see what happens!
  8. beltz5
    beltz5 Notebook Enthusiast
    Anyone know how to control the fan or if sony is working on a software update????
  9. ChocolateCake
    There is no fix yet. A Sony rep on the official support forum said they are looking at the issue, but so far no admissions or promises to fix it. You might want to follow this thread on the official Sony support forum:
    The Sony Vaio Flip and its noisy fan - Sony's Community Site
    If it is not fixed within 30 days after I receive my Flip, I will return it for refund. I suggest everyone do the same thing.
    Clerish and beltz5 like this.
  10. chbla
    chbla Notebook Enthusiast
    they keep ignoring it
    we have to put more pressure on them..
