Official Guide: Putting a P870TM1 CPU heatsink into a P870KM1 (P870KM to TM1 partial conversion)
Discussion in 'Sager and Clevo' started by DaMafiaGamer, Jun 19, 2019.
  1. matyee
    matyee Notebook Evangelist
    Thx but let me ask why?? The big gpu part could help the cpu. I have one 1080 this dual vapor is way too god for one card, however coudl help the cpu as it suffers from 9-series.
  2. Meaker@Sager
    Or just buy a new set.
  3. matyee
    I have already a tm1 vapor. Perect for the gpu 200w max 65degree. I am suffering on cpu side. Silicon lottery 8086k delidded, lapped km1 heatsink also lapped and barly stands under 80c auto fan 4,5ghz
  4. Papusan
    I dont think the «puke over heat HS design» help much for Cpu. Be sure you have perfect fits from HS over die.
  5. Meaker@Sager
    Which design are you puking over? Each has a plus and a minus.
  6. Papusan
    The old Vapor Chamber design. And also Clevo enginners saw how it would go with more cores.
  7. Meaker@Sager
    Made a lot of sense when combining a quad core CPU with 2 high consuming GPUs.
  8. matyee
    I am comsidering go with the heatsink direct die.... throwing out the ihs, get a der8auer oc frame, and put directly on the cpu die...
  9. Meaker@Sager
    You would need to modify the VRM contact area heavily along with the screw mounts.
  10. matyee
    which vrm contact?
