Offical Coffee Lake Refresh Upgrade Guide For MS-16L1/L3 (Eurocom Tornado F5) & MS-1T11 Vortex PC
Discussion in 'MSI' started by DaMafiaGamer, Feb 18, 2019.
  1. Kevin@GenTechPC
    Agreed, it's there to make user experience better and more enjoyable.
  2. FrozenLord
    FrozenLord Notebook Consultant
    Thank you very much for your time and effort that went into making this.
    I have just installed the MSI GT62VR variant on my Tornado F5 and it was a really simple and smooth process :)
    Now I just have to decide on which CPU to get, as I am still running my 6700K, which seems to be on the awful side of the silicon lottery.
    (It manages 4.2 GHz on all cores in non-AVX conditions with a voltage of only 1.25 V)
    Kevin@GenTechPC and DaMafiaGamer like this.
  3. thatwasonce
    thatwasonce Notebook Enthusiast
    Just to be perfectly sure the XOTIC G63 VALKYRIE 1070 is MS_16L3_GT62VR.rom correct ?
  4. thatwasonce
    FrozenLord, Talon and Papusan like this.
  5. SpacemanSpiff46
    SpacemanSpiff46 Notebook Enthusiast
    The old thread:
    http://forum.notebookreview.com/thr...de-guide-msi-16l13-eurocom-tornado-f5.821651/
    link to the the BIOS is down but I am assuming that even if I wanted to upgrade my F5 to an 8 series CPU that the BIOS in this thread will still work?
    Also, the pics in the old thread are also down but can I assume that the pin mod picture is the same between the 8 series thread and this 9 series thread? IE. the kapton cape would go on the locations marked in the pic in this thread on my 8086k?
    Thanks!
  6. thatwasonce
    Got a secondhand 9600k and here's some results on stock settings prime95 with AVX off (with AVX on it power limits to 95W)
    FrozenLord and Kevin@GenTechPC like this.
  7. FrozenLord
    Hey there,
    I have recently started to wonder what microcode is actually in this BIOS.
    So in case anyone else is wondering that as well, I would like to share my results :)
    You can find the tools I used in this forum: Microcode Modding @ Win-Raid
    After extracting the Microcode file with UEFITool, I had MC Extractor analyze it and got the following information:
    To look up the CPUIDs you can either use a website like CPU-World or consult one of the many Guides Intel provided.
    For example, I have used this one: Intel's Microcode Revision Guide (August 2019)
    Cheers
  8. deathwingbg
    deathwingbg Notebook Consultant
    Great work guys!!! Thank you!!!
    I updated the bios several days ago and now have the TF logo :) All great but I miss all the unlocked options in the bios to control the CPU/RAM etc..
    Is it just me or these "advanced" options are not available in this BIOS? The only options to overclock the CPU is ThrottleStop or the XTU?. Before that I was using custom unlocked bios from SVET for 3+ years.
    Just played with my 7700k yesterday … waiting for 9700k and custom water loop.
    The issue is voltages are totally off when set in ThrottleStop. I remember I had this issue before and set the settings directly in BIOS according to Mr. Fox's guide.
    For example I followed one of his TrottleStop guides. Set everything as he suggests. Set Voltage to 1.200 and multi to 49 … runs all benchmarks ok and goes to 1.222V according to TS and HWInfo but then when idle it goes to 1.4V+ and emits a lot of heat.
    Edit:
    9700К arrived but it won't boot. I think the pins are properly isolated (check photo). Any suggestions apart from non-working CPU? :)
    I installed the MS-16L1_TF_S5.rom
    Should I have installed the MS-16L1_GT62VR.rom
  9. deathwingbg
    Ok officially bricked my bios with the MS-16L1_GT62VR.rom :)
    Waiting for CH341 to debug :)
    @DaMafiaGamer please advise which is the correct bios for Tornado F5 and how can I make the 9700k work (eventually these days will test it on a z390 motherboard) :(
  10. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    What colour is the motherboard pcb in your tornado f5?
    Is it green or black?
