Odd CF-30 sound
Discussion in 'Panasonic' started by n4wwl, Dec 22, 2020.
  1. n4wwl
    n4wwl Notebook Enthusiast
    Hello all. I have several CF-30s that have been running Win 10 for over a year (even though Panasonic says the CF-30 is not compatible with Win 10). One recently started making an odd two-tone sound. It sounds like a notification sound and occurs randomly, but the sound is not associated with any Windows system notification or program I have running. The sound is audible even with the computer speakers off. It lasts only a fraction of a second, like a two-tone double beep (low to high), sometimes occurring only once and sometimes occurring two or three times in succession.
    Thinking it was an event notification, I have used Event Viewer and Process Monitor to find the sound but to no avail. I have checked online for other possible solutions but have found nothing that identifies the sound. I have run virus and malware scans that show the laptop is clean. I have monitored CPU and memory functions, but still can't pinpoint it.
    Because the sound occurs rapidly, randomly and infrequently it is hard to record it, but I will try to capture it and post it here. Does anybody have any idea what this sound might signify? Could it be an indicator of an impending hardware failure?
    Thanks for any help.
  2. CLASSIF1ED
    CLASSIF1ED Notebook Enthusiast
    Coil whine. Not harmful, just annoying.
  3. n4wwl
    Reassuring if true. And definitely a better answer than I expected. :) Although it sounds more like a double beep than a whine.
  4. Shawn
    sOUNDS LIKE A HARDWARE DISCONNECT AND RECONNECT.
    Sorry--caps lock
    Check battery / wifi card / wwan card etc...
  5. n4wwl
    Thanks. That sounds plausible. Will have to figure out how to check those components...probably a diagnostic built into the laptop?
  6. kode-niner
    kode-niner Notebook Consultant
    Yep! Hit CTRL-F7 a few times when it says press F2 for setup.
    Shawn likes this.
  7. n4wwl
    Thanks. Running it now. Will let you know what the results are.
  8. n4wwl
    Test just completed. All OK-GREEN. So it doesn't appear to be a hardware problem. That said, I have not noticed the noise today, which makes me wonder. The mystery continues...
