OC Satellite A500 with SetFSB?
Discussion in 'Toshiba' started by omnikam, May 27, 2010.
  1. omnikam
    omnikam Notebook Enthusiast
    Hi This is my fist post so please forgive my writing format :p
    I have a Toshiba A500 satellite with the Nvidia GT230M (harvey Norman custom)
    Id like to OC the P7450 intel duo @2.13GHz
    Im using SetFSB and have set the clock Generator to SLG8SP513V
    In Diagnosis i tested the Clock Generator and it seems to work when i press GetFsb, but when i alter the FSB via the slider and press SetFSB it resets to 266
    I then decided to edit the values in the Creator settings and Manually changed the FSB to 308 and pressed update. I then checked the results with the Diagnosis GetFSB button and it looked like the change had worked as the result came back FSB 308. But the CPU was still at 2128.1MHZ, unchanged from the 266 FSB default. I then Check With CPU-Z and discovered that the FSB was still at 266 even though SetFSB was reporting 308
    Does anyone know a solution to OC this Processor or perhaps a work around?
    Id be most appreciative of any help in succeeding with this venture
  2. moral hazard
    Any chance of a screenshot of the diag?
  3. omnikam
  4. moral hazard
  5. omnikam
    Thanks For your support Moral Hazard, ill look into PLL pinmod :)
    UPDATE. i used Sandra to diagnose my Mainboard and it said under Clock Generator, Yes to Programmable and yes to Read back support, so i dont think its TME is enabled. So it should be able to software OC. But im going to need the PLL
  6. User Retired 2
    Your PLL's byte 9 is 65h=1100101b. If your PLL has the same config registers as an ICS PLL (likely) then we see bit 6=1, so TME is enabled, no software overclocking possible. Would need the TME-unlock pinmod in Moral Hazard's thread.
  7. omnikam
    I was afraid of that :( Im under warranty so ill have to leave it alone for now. Im planning on putting a T9900 @3.06ghz in a month or so but thought it would be nice to see how far the P7450 can OC and remain stable. Though im not willing to void warranty in the pursuit. Still i must say you have all been very helpful so thanks again :)
  8. moral hazard
  9. omnikam
    Hey thanks for the link, looks good. And apart from the locked multiplier its the same as the T9900
  10. moral hazard
    Actually the T9900 also has a locked multi.
    The CPU is exactly the same as the T9900, the only difference is the TDP and I wouldn't trust that TDP anyway.
Similar Threads - Satellite A500 SetFSB
  1. StormJumper
    2
    402
