NVMe SSD using the same maximum link width
Discussion in 'Hardware Components and Aftermarket Upgrades' started by ellalan, Nov 22, 2017.
  1. ellalan
    ellalan Notebook Deity
    Could someone please help me solve this, maximum link width was 2x with old BIOS, I have updated the BIOS to the latest version, maximum link width has changed to 4x but current link width stays at 2x, do I need to reinstall my OS?
  2. tilleroftheearth
    Which M/B? What previous/new BIOS? Notebook or DT?
    Are you running Asus' XMP by any chance? (Disable it if you are).
  3. ellalan
    Hi tilleroftheearth, it's a Aspire F5-573, MB is Captain_SK, I have updated the BIOS from V1.12 to 1.27, could it be the MB restriction?
    tilleroftheearth likes this.
  4. tilleroftheearth
    Thanks for the updated info... (still need more)...
    Sorry, I'm not familiar with that particular model, but I hope others can help here...
    See:
    https://ark.intel.com/products/95443/Intel-Core-i5-7200U-Processor-3M-Cache-up-to-3_10-GHz
    If the cpu is the i5-7200u as in the link above, is there anything sharing that link or otherwise not letting it operate at x4 speeds? Is there anything you can remove/disconnect or disable in BIOS?
    Even though it seems like the processor is capable of those speeds on at least one port, it may be the M/B that is limiting it in other ways (power/cooling design/etc.).
    Can you give the full details on your system? Thanks. ;)
    ellalan likes this.
  5. ellalan
    Thanks tiller for the response, I am using Windows 10 IP build 17046 in this laptop, even at MLW of 2x it's lightening fast but I was wondering why the current link width stuck at 2x, anyway, thanks for your input :)
    EDIT: Yeah, this has happened in other makes of laptops as well.
    http://www.geektech.co.nz/high-performance-nvme-ssd-capped-at-pcie-2-0-speeds-y700
    I don't think the difference between 2x and 4x is worth the hassle, posting my speeds at the moment for you to compare.
  6. tilleroftheearth
    You're welcome. Seems like the BIOS/UEFI is determining that connection speed on your notebook, even if an appropriate component (x4) is attached.
    How is your search coming for an equivalent 'H2OUVE.exe' utility for your Acer? :)
    Would simply unlocking the hidden BIOS/UEFI features possibly help?
    See:
    https://www.bios-mods.com/forum/Thread-Please-help-to-unlock-Hidden-menu-in-Acer-E5-553G-T9VU-Bios
    The thread above seems to have a helpful individual that may lead you to a solution for your notebook. Proceed with caution and at your own risk! :) :) :)
    Good luck.
    ellalan likes this.
  7. ellalan
    Thank you tiller, very helpful :)
