NP8954 GTX 1070 MAX-Q --> GTX 1070 UNLOCK
Discussion in 'Sager and Clevo' started by mulzoffh, Dec 27, 2018.
  1. djsubtronic
    djsubtronic Notebook Evangelist
    Ok I tried doing what you did with the 125W BIOS and voltage curves. GPU temps remain below 72C, power consumption doesn't really go above 90W much and here are some benches:
    The graphics scores are a massive bump over stock without any increase in temps and only a slight increase in power draw... Voltage is also max 0.7625V.
    Seems like a win to me?
    mulzoffh likes this.
  2. mulzoffh
    mulzoffh Notebook Geek
    75 degrees or so in my room.
  3. Meaker@Sager
    Not bad at all with that room temp.
  4. mulzoffh
    So a couple more updates. Some weird stuff, at .7 volts, I just randomly lose 30 fps. If I put the voltage up to .75, I gain that fps back. I also am getting 4-5 more fps at 1550 MHz over 1625. Trying to find the best combo.
  5. Meaker@Sager
    Either it's hitting a weird power state/table condition or it's just not quite stable at the lower voltage.
  6. mulzoffh
    Here is my Time spy score at 1675.
  7. djsubtronic
    You got me beat on the 8750H vs 7700HQ :D
  8. k123cp
    k123cp Newbie
    I don't own the NP8954 but since this thread is the most relevant: how do you guys manage to score over 17k in firestrike? Flashed a full 125w (though not the one in the first post as size is different) 1070 bios onto my max q HP Omen and I only get ~ 15.2k (original bios is 90w, scored 13.9k). Also only manages a 1632@0.8v, anything lower than that the benchmark wouldn't run. Power consumption is ok averaging around 90w, and the improvement is noticeable but I still want to know if it could get even better..
  9. Meaker@Sager
    You may be hitting system power limits.
  10. djsubtronic
    That's weird, I got over 15.2 even on the stock 80W VBIOS. You're referring to the graphics score right, not overall?
