NP8954 GTX 1070 MAX-Q --> GTX 1070 UNLOCK
Discussion in 'Sager and Clevo' started by mulzoffh, Dec 27, 2018.
  1. djsubtronic
    djsubtronic Notebook Evangelist
    It could potentially be a lot more because 15700 is with a 160/400 OC whereas 16700 is on stock.
  2. Meaker@Sager
    Due to the turbo algorithm you cant look at set clocks but real clocks and then make a judgement.
  3. mulzoffh
    mulzoffh Notebook Geek
    Sorry I have not been on, but an update for y'all. I am able to unlock the sliders, but unable to flash modified files just yet still waiting on a modified version of nvflash.
    No issues over the past few months, I am stable at 1625 @ .750 volts. no overheating issues.
    I did upgrade my 150w power supply to a 230w for a massive boost in performance though as I was definitely topping out the 150w.
  4. stamar
    stamar Notebook Prophet
    did the ac adpater change right away the score?
  5. djsubtronic
    I'm already using a 200W adapter, can I ask how you unlocked the voltage slider? And are you using the 125W or the 115W?
  6. mulzoffh
    I am using the 125w, and I didn't unlock the slider. I am using the curve part in msi afterburner to raise my clocks in a flat line from .750 volts onward at 1625.
  7. mulzoffh
    It didn't so much change the score but made system stability much better plus my cpu now doesn't underclock itself as the power supply struggles.
  8. djsubtronic
    Ah I see, what kind of max GPU temp do you get with this configuration under max load (i.e. gaming/benchmarking)?
  9. mulzoffh
    I see max 75-80c while its on its laptop cooler.
  10. Meaker@Sager
    What sort of ambient temp?
