NP2090 Wait Times
Discussion in 'Sager and Clevo' started by Setreal, Jul 13, 2007.
  1. Setreal
    Setreal Notebook Enthusiast
    My current notebook has been giving me problems for quite some time and finally died today. While I had been planning on getting a new notebook now I'm left without a computer which is quite a problem. I started looking around and it seems the NP2090 is my best option but there seems to be shipment issues. If I was to order today could I expect it reasonably soon or should I go with something else?
    EDIT: Forgot to post the specs I wanted. I'd be willing to change the screen and such if that's an issue.
    Sager Notebook NP2090-V Elite
    - 3 Year Labor* 1 Year Parts Warranty Lifetime Toll Free Tech Support (Extra 2 Year Labor Warranty through Xotic PC)
    - None Standard
    - None Standard
    - ~Windows Vista Ultimate 64-Bit Installed (64&32-Bit CD Included) w/ Drivers & Utilities CD's
    - None Standard
    - None Standard
    - Integrated Fingerprint Reader
    - None Standard
    - None Standard
    - None Standard
    - 110/220V 120W Auto Switching AC Adapter - Included
    - Smart Li-ion Battery (9-Cell)
    - Carying Case Optional (Select if desired)
    - None Standard
    - Built-in Intel® PRO/Wireless 4965 802.11 a/g/n
    - Internal Bluetooth 2.0+ EDR
    - Integrated System Speakers - Included
    - 15.4" WSXGA+ "Matte" Type Super Clear Ultra Bright Screen (1680x1050)
    - Arctic Silver 5 Thermal Compound
    - Standard Dead Pixel Policy
    - ~Intel® Core™2 Duo T7700 2.4GHz w/4MB L2 On-die cache - 800MHz FSB
    - 512MB PCI-Express nVidia GeForce 8600GT DX10
    - None Standard
    - ~ 4,096MB DDR2 667 PC2 5300 (2 SODIMMS) Dual Channel Memory (w/ Vista 64-Bit Only)
    - 1GB Intel® Robson Turbo Memory (Vista Only)
    - Standard Finish
    - - Combo Dual Layer SuperMulti 8X DVDRW Drive w/ Software
    - ~ 160GB Seagate Momentus 3GB/S SATA 300 7200RPM Hard Drive
    - None Standard
    - Internal 4-in-1 Card Reader (SD/MMC/MS/MS PRO)
    - Built in 2.0 Megapixel Camera
    - None Standard
    - Sound Blaster Compatible 3D Audio - Included
  2. wolve
    wolve Notebook Guru
    From what I've read in these forums, the next shipments of NP2090s with WSXGA (1680x1050) screens aren't coming until late July. So the soonest you can expect to get one if you order now is early August. I think mid-August is a more realistic estimate.
    Also worth noting is that 2 GB RAM sticks are in short supply. You may want to consider a different laptop since you need a new one ASAP, or downgrade your configuration on the NP2090.
  3. sco_fri
    sco_fri Notebook Evangelist
    There are posts regarding the shipping times that can be expected in the Compal and Sager sections with a little digging, and they are explained for each screen resolution as well as with extras such as bluetooth and the tv tuner. I can tell you that there is not set date for WSXGA.
  4. Donald@Paladin44
    Donald@Paladin44 Retired
    Well, it depends on what you mean by "reasonably soon". When do you actually need it?
    Actually, the best thing to do is call the resellers.
  5. Setreal
    I ended up going with the NP5970 since they started their shipments today and there's certainly nothing wrong with it (just pricier). Thanks for all the help.
  6. Donald@Paladin44
    What resolution did you get?
    I only ask because if you got the WSXGA+ (1680x1050) that is in your first post...those have not come in yet.
  7. lemur
    lemur Emperor of Lemurs
    You mean NP5790, no? I can't see any 5970 anywhere. If that's the case, then the thing wrong with it is size (and weight probably). That's a deal killer for me.
