Notebook fan control?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by NotebookAholist, Aug 14, 2007.
  1. NotebookAholist
    NotebookAholist Newbie
    Hi,
    Does anyone know if there´s a program that can be used to control notebook fan speeds? Asus A6JA runs extremely hot long before the fan even starts to blow so it would be nice to manually make it work earlier.
    Thanks for all the info in this!
  2. revogsx
    revogsx Notebook Guru
    yup.. i'm using it right now on my asus a6ja
    search for SPEEDFAN
  3. someone777
    someone777 Notebook Evangelist
    You can use Speedfan
    but other product i heard of ppl using it is Notebook Hardware Control.
  4. Amol
    Amol APH! NBR Reviewer
    I think you can also try Rivatuner. Read this guide:
    mosey mosey
  5. Anadhi
    Anadhi Notebook Consultant
    hey guys, does speedfan and nhc automatically detect the fans? I have installed both and I still have no clue to increase the speed of my fan or to detect them using both programs.
  6. flipfire
    flipfire Moderately Boss
    You can only change the fan speed on certain notebooks. The fan algorithm is hard coded into the BIOS.
  7. Anadhi
    Oh no, I have checked my bios, and it seems it doesn't support fan control at all -_-
  8. Tusin
    Tusin Notebook Evangelist
    Maybe see if there is a bios update for your laptop? My old HP DV6000t (just got a M1530 but it is probably the same thing), fan speed would change between the different bioses.
  9. flipfire
    different bios's may alter the fan algorithm.. but he wants to have customised control of the fans.
    you can do it with i8kfangui on dell notebooks
  10. anarky321
    anarky321 Notebook Deity
    i use this for my overclocked vostro 1500 ...works great; you can set custom fan speed points
