Notebook Coolers : A Buyers Guide
Discussion in 'Accessories' started by X2P, May 23, 2008.
  1. jaug1337
    jaug1337 de_dust2
    Make a new thread when you get around :D
  2. -BaTaB-
    -BaTaB- Notebook Geek
    Dang. Had some work/life issues to solve. I guess I'll make up the mod next week but I already have everything I need I think :D
    One thing I already noticed though is that the new notepal U3 is not as stiff as the old one. Or, well: the new one is not super stiff and those who could try both the new version and the old version (new is U3+, old is U3), said the old one was stiffer. I only have the new version unfortunately.
    If you like to type with laptop keyboard and you do it fast there will be some small vibrations. I want to see if using 120mm fans will also help by stiffening the whole structure. Otherwise i guess i'll might need to find two small aluminum profiles to fix this "issue".
  3. leftsenseless
    leftsenseless Notebook Evangelist
    I'm trying to mod a U3. What would I need to control fan speed and plug into an outlet. I haven't received the U3 yet. I'm trying to figure out what i need to buy to make everything work.
    Papusan likes this.
  4. Papusan
    Take a look here
    leftsenseless likes this.
  5. kmeck518
    kmeck518 Notebook Enthusiast
    1) Budget
    <$50
    2) Is noise an issue for you? Are you annoyed but noticeable noise?
    would prefer quiet
    3) Post a picture of the under side of your notebook along with basic measurements like shown earlier in this guide. (just link to a previous post if your notebook has been posted before)
    http://www.hidevolution.com/media/c...ab33525d08d6e5fb8d27136e95/p/6/p670hp-g-9.png
    edit: dimensions are 16.42” (w) x 11.30” (d) x 1.18” (h)
    4) Do you have a color preference?
    none
    5) Any brands you would like to avoid?
    none
    I'm looking for a laptop cooler that i can actually use in my lap. I've got a Clevo P670HP6-G. I was thinking about this Cooler Master x3, but i'm skeptical about how it would work on a laptop. Just typing in laptop cooler for lap into amazon i found this one from tecknet which looks like it could work well being that the intake for the air is from the sides.
  6. NIGHTMARE
    NIGHTMARE Notebook Evangelist
    Suggestion for P870TM1
  7. NIGHTMARE
    How is HD3 Gaming Chill Mat
  8. NIGHTMARE
  9. Papusan
    Useless. Flush the airflow from the two fans right into the bottom lid where it is no grill holes will do nothing. Wasted money! Most of laptops have grill holes on the upper side on bottom lid. Many with grill hole on each side (left and right). Not in the middle lid.
    Ashtrix likes this.
  10. NIGHTMARE
    I think only U3 plus is best cooling pad ?
    Papusan likes this.
