Notebook Battery Guide
Discussion in 'Hardware Components and Aftermarket Upgrades' started by chrisyano, Dec 6, 2006.
  1. arsenal71
    arsenal71 Newbie
  2. arsenal71
    arsenal71 Newbie
    thank you i found that in bios i cannot find that one in samsung utilities
    now if i want to go somewhere with the laptop what i have to do to charge the battery 100%? change the settings again ?
  3. davidfor
    davidfor Notebook Consultant
    I had the name wrong. As someone else said, it is called "Battery Life Extender". It should be in the Samsung folder in the porgrams menu.
    Yes. Then you have to reboot and let it charge to 100%.
  4. arsenal71
    arsenal71 Newbie
    yes i found it thank you verry much again
    how is better when is not use ,when is off to unplug it or just live it as it is
  5. HopelesslyFaithful
    HopelesslyFaithful Notebook Virtuoso
  6. HTWingNut
    HTWingNut Potato
  7. beebo_cakes
    beebo_cakes Notebook Enthusiast
    Ah, and this was why I posted a thread on my own about my issue with batteries. I read this guide and several other websites where people were saying it's bad to keep the charger in and where people say you should unplug the charger.
    Being that I have an Asus Zenbook, I can't remove the battery. So the battery degrades anyway even if I don't use it. But does leaving the charger in, make it degrade faster?
    Is it better to leave the charger in at 100% and just use it without the charger when needed, OR is it better to unplug at 100%, let it drain and then charge it again?
    And I read there's an option for some laptops that you can you disable battery charging in BIOs. I couldn't find that option for myself.
  8. HopelesslyFaithful
    as i said before...don't listen to people that tell you to unplug it at 100%...that is terrible for the battery because your forcing the battery to cause unnecessary wear. plus its extremely inconvenient.
  9. JOSEA
    JOSEA NONE
    1. No, it will stop charging when capacity is reached.
    2. You should drain it once in a while from what I have read.
    3. I have not read of any ASUS with that feature.
  10. Ferrari353
    Ferrari353 Notebook Evangelist
    Are there any programs that counts my charge cycles and tells me when it's time to do a calibration?
