No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. dinsdale79
    dinsdale79 Newbie
    Hi, I have a problem with my asus zenbook ux31a. A friend of mine replaced a faulty power jack for me. After that while assembling the laptop I connected the LCD strip with the battery plugged in. I've heard some cracking noise and now backlight is gone.
    I showed the laptop to two different "laptop repair specialists", but it turned out they're not really that good. One told me that there's something wrong with the motherboard, but he doesnt know what (he checked all the fuses he said). The other said the led backlight is faulty and I have to replace the whole upper lid.
    Is damaged baclight itself possible in my case? Or it's rather the motherboard?
    Another interesting thing is that the laptop doesnt do anything after I close the lid, eventhough I set up in win10 that it should hibernate after lid closing. So it got my suspicious about the reed sensor. But the keyboard is working fine. Faulty reed sensor would block backlight and the keyboard, right?
    Also I can't power up the laptop normally. Every time after shut down I have to disconnect the battery, reconnect it and then plug in the ac adapter, then it starts automatically without even pressing the power button.
    Befor that unfortunate laptop assembly everything was working fine.
    Any help would be greatly appreciated.
    EDIT:
    I checkd LVDS pins. Here are the values:
    pin 8: 19V
    pins 13 and 14: 0V
    pins 18,19,20: 3.3V
    Looks like faulty U4501? Anyone knows correct values for pins 13 and 14?
    [​IMG] [​IMG]
  2. SjoerdG
    SjoerdG Newbie
    Hi everybody.
    incredible handy forum you have here. I searched the history of this thread in the hope
    of seeing the motherboard of my Vaio coming by, but no luck. Therefore I am writing this post.
    I purchased a Sony Vaio PCG-81313m (used but in great condition) for my fiancé as
    an extra Christmas present because her old notebook broke down. Unfortunatly the screen got
    cracked during transport.
    I installed a new screen, but hasty to do it while she was out of the house,
    forgot to take out the battery. Now the backlight does not function any more.
    So the model name is PCG-81313m, the product name is VPCF24P1E.
    Mainboard is the MBX-243 V081-MP_MB Rev 1.1. It has a 16,4" Full HD LED screen.
    The screen has a 40 pin connector, but no separate backlight connector.
    Here a picture of the front of the mainboard, with the connectors marked. The 40 pin connector
    on the screen leaves the screen area as 1 cable, but the cable is divided on the motherboard
    where it connects to those 2 plug-ins.
    https://drive.google.com/open?id=1JhGOXDqLW7IkhAkT19vHQTASBkqheg2m
    Here a picture of the connector area.
    https://drive.google.com/open?id=19GEw8m7rQYVjGF16gWJnQARXUrJY-gPz
    And a picture of the backside. Red are the connector area's on the other side.
    I did not paint over any writings or diode's/fuse's.
    https://drive.google.com/open?id=1CsCj8FVd3TVI-as1b2CGPahVAc0bcd04
    Here also a picture of the backside of the screen, and the connector area on the screen.
    I noticed there is also a small fuse on the screen, so included this picture to be sure.
    https://drive.google.com/open?id=1WZrQ4WYQJy0QxZ3r0l_XblW4hVvGG6wn
    https://drive.google.com/open?id=1pAFgLo1WiV2Y0Kk1BEJjfE9D8Rokn2Zc
    Is there anybody who could guide me to the solution, by pointing out the possible fuses?
  3. Napalm_Death
    Napalm_Death Newbie
    Do you know how to check continuity in fuses with a multimeter? Check P02 and similar fuses on the motherboard. on the lcd check the white ones, look like fuses to me.
  4. postfire
    postfire Newbie
    hello anyone!!
    please help for my problem plz?
    i have a laptop clevo W251HN (turbo x) and it no backlight for the screen
    the screen is ok tested to another laptop
    maybe it has problem in fuse on backlight but i dont know where is the fuse on the motherboard for this laptop
    please can you help me to find the fuse?
    thank you!!
  5. zumnao
    zumnao Newbie
    You can get a multimeter and start testing all fuse and little smd resistances, specially around screen plug on mother board.
    Check continuity on both poles (sides), if you get continuity fuse is right, if there is no then bingo.
    Good luck!
    Enviado desde mi SM-A520F mediante Tapatalk
  6. postfire
    postfire Newbie
    finally i found the fuse and fix it
    the backlight screen is ok now
    i post photos to help another users
    thank you!!
  7. pawel_
    pawel_ Newbie
    Hi there. Thank You guys for all the useful information in this topic!
    I have a problem with the backlight in my old VAIO SVE14A1S6EW and thanks to your knowledge i am close to solve it.
    However, I would like to get an advice before I'll start soldering :)
    The place at mobo where the LED fuse is supposed to looks slightly different from the one posted a few years ago. Probably different rev. The elements are arranged in different order.
    Could you please help me with identifying correct fuse to bridge here? Is it "S" ?
    I will be very grateful for any help.
    https://imageshack.com/a/img923/1294/2ckknO.jpg
    EDIT: Tried with the "s" one, and backlight is back. Info just in case anyone needs it in the future.
  8. jonasvarnas
    jonasvarnas Newbie
    Hi,
    could someone help me with mbx-206 motherboard (sony vpcz1). Where is backlight fuse on it? I cant find schematics for mbx-206 anywhere. Thanks for help.
  9. Zwiero
    Zwiero Newbie
    Hi Guys,
    I wonder whether you could help me with my issue
    I think i have the similar issue but with Vaio SVP13, i was replacing the palmrest with keyboard, and after connecting everything my touchscreen didn't seem to work, so was detaching the cord for LCD/Digitizer (stupidly with battery attached), so the computer became unresponsive, at firs was up to wait couple of hours for the voltage to leave the motherboard, but was impatient and I removed the CMOS battery and now its starting but resets BIOS (i have modded the BIOS to support NVMe drive), and the screen is black (no backlit, and screen is not detected), it works with external monitor, however i need to mod BIOS every time i start the computer to run from NVMe drive, the computer does not detect the monitor, so i was thinking that maybe by adjusting the cord from LCD/Digitizer i have disconnected cord from LCD, but this BIOS resetting to the safe state and removing NVMe instructions might indicate the fuse problem
    I've tried to jump start 'S' fuse (in the pic from url on the left), but it didn't work (maybe was doing it wrong), and since there is no backlight nor display detected in windows this might be just and issue of the LCD cable.
    http://laptopturn.com/wp-content/uploads/2017/11/CHEK-BOTH.jpg
    I've examined all the fuses but they seem to be fine,
    Want to try later today check the direct connection to the lcd, whether it have been disconnected, otherwise will have too examine that with proper gear next week,
    Do you guys have any suggestions or any possible solutions?
    I'd appreciate in advance all of them, thank you
  10. gremlin90000
    gremlin90000 Newbie
    Hey guys, I have the same problem - blown display fuse on SVP132 (tested it with my multimeter). I'd like to order a new fuse but I don't know how it's called! Would you kindly let me know what I should be looking for (like fuse type and it's voltage or amperes) because I already spent hours googling with no result. I can't even get close to it and my "local" electronic store won't read local forum, I have to do 2 hour drive to get there.
