No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. zeros000
    zeros000 Newbie
  2. vanotti
    vanotti Newbie
  3. vanotti
    vanotti Newbie
    I think is that. true?
  4. ebra.ah
    ebra.ah Newbie
    hi
    no back light on led screen SONY VGN-Z720D MBX-183
  5. ebra.ah
    ebra.ah Newbie
    Hi fuse ok 19v
    But again, I do not backligt
    back light not enable
  6. GELongoria
    GELongoria Newbie
    The screen on my Sony VAIO model PCG-6161L (VPCEE3WFX) goes dark after some time of use and then would sometimes come back on. I am pretty sure it is the lcd backlight failing because the rest of the laptop works fine while sitting on my desk plugged in to an external monitor. Further, I can shine a bright fashlight on the darkened laptop screen and see the contents.
    I thought maybe the power inverter went bad but it is an LED model so not sure that it has one (at least I didn't see one in the center bottom location when I pulled the bezel off)? I also questioned whether the lcd power fuse burned up as reported throughout this thread. But then while the screen is out and plugged into my desk monitor, after an hour or so, poof, the laptop backlight comes back on, so maybe it's a loose wire? But if loose, why does it come back on even if the laptop is sitting unmolested.
    Before I tear it down and start ordering random parts, does anyone think it might be driver related? Despite Sony not supporting it, I upgraded this laptop to Win 10 a few months ago, before this odd LCD problem started. But it seems like this latest LCD outage fixed itself after the latest Windows cumulative update.KB4015217 (release for Windows 10 version 1607)
    Indeed I found in the notes for KB4015217 (bumps the version number of Windows 10 to build 14393.1066)
    that it "Addressed issue where displays turn off unexpectedly even when Turn off display and Screensaver are disabled in the power profile." I'm obviously grasping at straws with this but again, figured I'd ask before tearing down the computer looking for a loose wire or solder.
    Thoughts anyone?
    Thanks for any advice.
  7. Ptit-loup
    Ptit-loup Newbie
    Hi all Im new here but see conversation and need your help .
    I have hp tm2 1050ef laptop.
    I broke screen . Change it .
    See it was not really the same (good was b121ew09 and try to Plug ltn121at09 )
    The backlight dont turn on . In without fail mode I can start m'y laptop and see screen without problem Just no backlight.
    In normal mode (windows) it wont work.
    So I think this is windows issue but for backlight I think maybe this is fuse issue ?
    Problems are same with good screen références.
    I leave you pictures of my motherboard and hope you can help me .
    Ps I have tried the fuse1 (110) in top and fuse 1001 (110) near usb in right. All of 2 are at 0.5
    [​IMG] [​IMG]
  8. Eddyboy911
    Eddyboy911 Newbie
    Thanks to the man who created this thread.... thank you so much.. i don't know so much about hardware still this thread helped me.. now my laptop is back on track.. fuse [ s ] was the main culprit...
  9. claan
    claan Newbie
    With your help i got backlight back on my SONY VAIO.
    Thank you.
  10. michaelenergy
    michaelenergy Newbie
    hello, is there someone that can say to me where is the fuse located? it is a sony vaio VPCEA1S1E
    [​IMG] [​IMG] [​IMG] [​IMG]
