No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. zumnao
    zumnao Newbie
    Hi ngvuanh!
    Glad to see you're back.
    VAIO VPCSA3L9E
    Yes finally I did replace the wrong LCD spare for a new one that works. But I also got a new problem, no sound and no lan network.
    I've checked all drivers setup, everything is well installed and up to date but I got no sound at all, not inner speakers nor headphones. I don't care that much about LAN Ethernet as I have working Wi-Fi.
    I disassembled the whole thing twice but found everything well connected, I also changed win10 to original win7
    I'm afraid there could be another blown fuse or I could damaged the motherboard when bridging the fuse.
    Today I'll dissasemble it again and use a better magnifier to check the soldering area.
    Any clue will be well received
    I'm not sure this is fuse related if not sorry for the off-topic
  2. Devilsam96
    Devilsam96 Newbie
    Hello ! I have the same problem, no backlight. I have a Sony vaio sve 15" series.. I make some photos of the mobo, someone can help me to identify the problem or the broken fuse? http://imgur.com/a/Z3jHr
  3. Devilsam96
    Devilsam96 Newbie
    Can be it?[​IMG]
  4. iskafandra
    iskafandra Newbie
    ngvaunh, your work is great!
    I have the same problem with a Sony VAIO VPCYB25AL - Model: PCG-31311U. I found some fuses, can someone help me? I attached photos!
  5. joshaybee
    joshaybee Newbie
    Has anyone had much luck finding the fuse for the Sony Vaio Duo 13 Pro - SVD132?
  6. jacobtc
    jacobtc Notebook Consultant
    So I purchased a defective Vaio Pro 13, which would not display anything on the screen, however the HDMI output works.
    I purchased a whole new screen assembly in the hopes that it would work, however still nothing. I took a flashlight and found that it was the backlight which was dead. I know how to solder, and have no problems with a multimeter, however I have never fixed a backlight fuse before, and I have no idea where the fuse is positioned. I took a picture of the display connector and the area around it, does anyone know where the fuse is? And could I just remove the fuse and solder between the pads to short it, to make it work?
    Image: http://imgur.com/RX3ViTE
    gremlin90000 likes this.
  7. ngvuanh
    ngvuanh Notebook Deity
    It's been long time checking this forum. Sorry for late answers.
    @jacobtc, the fuse is a little one with letter S on it. You can bridge it or remove and short 2 pads are which ever best for you.
    Sent from my D6616 using Tapatalk
  8. ngvuanh
    Sorry, it could be late but I just want to give a reference
    fedecaba likes this.
  9. loukas599
    loukas599 Newbie
  10. loukas599
    loukas599 Newbie
