No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. SimpleAs-123
    SimpleAs-123 Newbie
    Yes I'm 100%, I replaced a cracked LED screen just few days ago and the backlight was out on both new and old screen, this is driving me crazy as everything works but the backlight, I can see the images with a flashlight up against the screen and it's LED as there's no inverter and the model number PCG-71811W VPCEH26EA which only come in LED option
  2. SimpleAs-123
    SimpleAs-123 Newbie
    Well, I gave up, thank you for all your help...
  3. badmau5
    badmau5 Newbie
    wow, amazing thread just fixed my friend's vaio vpcej28fx. Same problem with blown f4 fuse, after lcd panel replacement, fuse had big "H" on it, bridged it with solder - boom worked like a charm. Thanx to everyone!
  4. biustech
    biustech Newbie
    hi i just found this topic here about the backlight issue on led displays and i have a sony vaio VPCEA4S1E and same problem cracked display ordered a new one and now no backlight
    and just to make sure i will do the right thing can someone check the pic below and let me know if the fuse to bridge is the F15 with "n" on it. That is the region right under the lcd connector.
    thanks in advanced
    lucas
  5. ngvuanh
    ngvuanh Notebook Deity
    It could be the one.
    If you have a ohm meter, you will find out.
    It's also worth a try.
  6. biustech
    biustech Newbie
    That's fantastic! It worked :D
    Just bridged the fuse in the pic above and poof! backlight came back!
    Thanks for the support. And hope everybody with the same issue can repair too.
  7. senhorka
    senhorka Newbie
    Hello!
    I had the same problem and used the bridge to solve. I really appreciate everyone's help. My notebook is VAIO PCG-61411L
    Now I wonder where I can buy the fuse N to do the job the right way because if it's there is because it has some utility.
    Thank you!
  8. iptech
    iptech Newbie
    I've got a Sony VAIO VGN-TZ31WN with the same problem. I've just replaced the LCD panel and have no backlight. The screen works perfectly well on a similar TZ computer so I know it's not a fault with the screen panel. There are two options I can think of - either the hinge switch is sticking down or the the fuse, as mentioned above, is blown. Problem is I can't find either!
    Anyone help on this, especially the hinge switch as I can't believe I cannot find it, on most laptops they're obvious.
  9. ismae55
    ismae55 Newbie
    Hi im kind of new to this stuff and have the sony vaio VpcEE3WFX with the backlight issue i have searched google for months before i found this this thread and was wondering if you could please help locate the fuse and what is bridging it mean below are the pic thank you in advance DSCN2785.jpg DSCN2787.jpg
  10. ngvuanh
    You should have a steady hand to take a picture.
    Those blurry pictures like these are really hard hard to see.
    However, the small green one in the last picture could be the one.
