No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. roninra
    roninra Newbie
    man you are great thanks i will get back with results of the soldering i suspected that this might be it its marked " 14 " i will just short the fuse and will see thanks again :)
    soldering done and its working perfect thanks again this forum is great... im doing bit of fixing myself reballing dead graphics ps3,xbox,laptops, now dead led backlights ^^ :) still learning... everyday. thanks again rob
  2. coh1
    coh1 Newbie
    I have a PCG71313M laptop with a similar problem , would you have a photo of which fuse to check on my motherboard,, thanks
  3. ngvuanh
    ngvuanh Notebook Deity
    Your laptop is EB series, so F16 will be fuse for LED.
    Look at the photo on page 3 to see where it is in your laptop's board.
  4. SimpleAs-123
    SimpleAs-123 Newbie
    Please help, I have the VPCEH sony laptop and I can't seem to locate the fuse, has anyone looked into this model before? on the bottom the model is PCG-71811W, many thanks in advance
  5. ngvuanh
    If you want to fix the issue, sooner or later you have to take the board out.
    Let take the boad out and take a photo of both side around the LCD connector, so people can help.
  6. SimpleAs-123
    SimpleAs-123 Newbie
    Here are the pictures of both sides of the mainboard by the cable, the part that looks burnt is from me thinking that was the fuse and soldering a bridge but that wasn't it..
  7. ngvuanh
    I believe F4 fuse on the side of the LCD connector (next to it).
    It is in brown color with white H letter.
  8. SimpleAs-123
    SimpleAs-123 Newbie
    I actually tried to bridge that one first and the backlight still doesn't work..
  9. SimpleAs-123
    SimpleAs-123 Newbie
    So I bridged F4 and no luck, is it possible that I need to bridge boht the F4 and that green one on the other side labeled as D?? My multimeter shows both of them as 20 intead of 0...
  10. ngvuanh
    Are you sure that you have LED LCD and only backlight is out?
