No Backlight on LED screen
Discussion in 'VAIO / Sony' started by nebage, Sep 27, 2011.
  1. nebage
    nebage Newbie
    HI all, Im at my wits end, and with Sony also. My screen cracked thanks to the airlines. I've replaced the screen, and now have no backlight. I also tried replacing the hard to find cable, still no joy!, I've check screen model numbers, still no joy, I even put the cracked screen back in and now there is no backlight on that. I found a forum on Dell inspirions on with same issue and they talk about a fuse. I found what I think is the fuse, test with no connectivity, tried a iron solder ball and still no luck! Any ideas, Im out of my frigin mind and SONY want Over $600 odd to fix!
    thanks
    Ben
    Ejcriado and jackaxle like this.
  2. lilizerg
    lilizerg Newbie
    Most likely a fuse issue.
    I just fixed mine (model: VPCEA24FM). EXACTLY same issue: I left a thumbdrive on the keyboard and someone closed the laptop for me == broken screen (the screen still lights up, displays white screen only). I replaced the screen myself, no backlight since then......
    I checked tons of forums, there are a lot of people facing the same issue, but there is not a cure for my exact model, the most close one is some guy replaced a fuse (F7 for his case) on a sony notebook motherboard and fixed it. Others are mostly Dells laptop, they replaced either F1 or F8 depends on the model.
    Enough about the background. The infomation I got from these forums drives me to examine the motherboard of my laptop. I checked carefully and tested most of the fuses on board. Finally found one fuse is blown. That fuse was labeled as F16 near the plug for lcd screen on the motherboard. It should be 0 ohm, but tested as 20 ohm. then I applied a solder blob on it. I know, I should not do that since I have already ordered several small fuses and they are on the way, but I can't wait... It turns out that is the correct fuse! Luckly, my laptop doesn't have any shorts for the screen circuit. It lit up right after I put everything back and pressed the power button.
    I took pics of the location of that fuse for other people who is stucked like I did. But I just registered here, not sure whether I can upload any pics, I will try.
  3. lilizerg
    lilizerg Newbie
    Here are the pics, if they show up properly.
  4. xxGenericSNxx
    xxGenericSNxx Z1 Fanboy
    Just curious, did you check in your computer?
  5. lilizerg
    lilizerg Newbie
    Oh, I forgot to mention: Since those fuses are tiny, the testing pins of your Ohm meter has to be really clean, especially the tips of those pins, or you can sharpen the tips if you don't mind damaging your Ohm meter. Another thing you need to consider is the motherboard may collect some dust on the fuses which might cause false reading. I found several fuses on my motherboard tested with high or no connectivity first, but after I wiped the fuses with alcohol and sharpened my testing pins with sand paper, they were all tested as good fuses(0 Ohm). Hope this could help you find the correct fuse.
  6. doubleaa93
    doubleaa93 Newbie
    ty lillizerg!! your pictures helped me find the fuse on my sony laptop and the backlight is working now :)
  7. stefk
    stefk Newbie
    Hi to all , i have the same situation here , my laptop is a VPCCW1S1E can anyone tell me where is the fuse in this model? i searched everywhere i only find one under the screen plug on the mobo that says F 1 7 ..? can anyone help ? thanks ....
  8. beaups
    beaups New Jack Hustler
    ^post photos of the board.
  9. SOADam
    SOADam Notebook Enthusiast
  10. stefk
    stefk Newbie
    here are some pictures from the up side of the mobo near the screen plug
    thank you all for the reply
