NFS Hot pursuit (2010) Optimization Walkthrough
Discussion in 'Alienware M11x' started by L1qu1d, Nov 19, 2010.
  1. L1qu1d
    L1qu1d Notebook Evangelist
    1 - Go to C:\Users\L1qu1d\Documents\Criterion Games\Need for Speed(TM) Hot Pursuit or w.e it is on your computer.
    2- Open config.NFS11Save with Wordpad/notepad
    3- Configure it like this:
    [Hardware]
    AdapterNumber=0
    [Display]
    Width=1366
    Height=768
    ForceAniso=false
    HiResTextures=true
    MotionBlur=false
    DepthOfField=false
    FitToVertical=true
    GammaRamp=1.150
    [Settings]
    Webcam=
    ShadowMapLevel=0
    [Sound]
    SpeakerSetup=0
    HighQualFilters=0
    I now get 35-40 fps.
    Step 4- This might have helped but didn't check, set game to Priority level high!
    Happy Gaming!
  2. meomeo986
    meomeo986 Notebook Geek
    Sir, this is for R1 or R2?
  3. L1qu1d
    My mistake, I thought I had wrote it, its been tested on r1, it will prob help R2 as well, but I think R2 can enable a little bit more:)
    The game still looks great, other than motion blur u wont notice anything else:)
    my frames were a constant 15-22 fps, now are 35+:)
  4. L1qu1d
    Also turn off any antivirus while playing, this game really chugs th cpu! I also tested it with overclocked graphics and the frames went up 4-5 frames at times:)
  5. exbee
    exbee Notebook Enthusiast
    how do you set the game to priority level high? i try to in windows task manager and it says access is denied
  6. L1qu1d
    You might need admin enabled, you might be setting it to Realtime, which gives access denied I believe:)
  7. L1qu1d
    Double post
  8. leo6love
    leo6love Notebook Consultant
    +1
    much better, thanks L1qu1d.
  9. L1qu1d
    Also you can try enabling ForceAniso=true I found out, but make sure you OC your video card, other wise it might have some hiccups!!!!
    Enjoy!!!! Expect more frame drops when playing as Police!!!:D
    Great game though
  10. FernKomoYo
    FernKomoYo Newbie
    eii dude thx for this, but i have some problems with it, i still under 12 fps, it could be intel hd graphics?
