New ultrabook with longest battery life
Discussion in 'What Notebook Should I Buy?' started by Mr_Mysterious, Nov 3, 2019.
  1. Mr_Mysterious
    Mr_Mysterious Like...duuuuuude
    General Questions
    1) What is your budget?
    Up to $1600
    a. Ultraportable; 10" - 12" screen
    c. Thin and Light; 13" - 14" screen
    3) Which country will you buying this notebook?
    US
    a. Like: All
    b. Dislike: Apple
    Yes
    Browsing and netflix
    Yes
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    No
    As much as physically possible
    Without seeing it is fine
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows 10
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Specifically 1080p
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Matte screen if possible
    Build Quality and Design
    Not important
    Notebook Components
    15) How much hard drive space do you need?
    Not important
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    Now to about 3 months
    17) How long do you expect to use this laptop?
    As long as possible
    18) How long could you afford to do without your laptop if it were to fail?
    Not very long
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    Yes, I'd pay extra for on-site warranty.
    I'm looking for an Ice-Lake laptop that is under 3lbs, specifically has a 1080p screen to maximize battery life but has at least 350 nits of brightness, with Thunderbolt 3, WIFI 6, Bluetooth 5 and 16GB of RAM. My priority here is to get something that has as much battery life as possible.
    i5 is preferred, but not necessarily needed as I can massively undervolt and underclock an i7 if it means more battery life.
    Here are my options:
    HP Spectre x360 13t (Ships in 2-3 weeks, but has the longest battery life, allegedly)
    Dell XPS 13 7390 (least stylish, but also very promising)
    Dell XPS 15 7950 (cheapest option, but I can upgrade the RAM and SSD myself. Also has an insane 97 WHr battery!)
    Lenovo C940 (good keyboard, lots of battery life, uncertain about the screen).
    MSI Prestige 14 (great price, not sure about their support).
    I'm also looking for other suggestions if people have any other models they'd like to recommend.
    Mr. Mysterious
  2. Mr_Mysterious
    Bump! Does no one have an opinion?
  3. jeremyshaw
    jeremyshaw Big time Idiot
    7590 is 4.5lbs with that 97Whr battery, and there is still a risk of getting an 87Whr battery (which Dell will claim is "normal wear."). It also uses a full power H cpu, 14nm, and doesn't really get that great battery life... though it is good enough. There are a few strong reasons why I am using the XPS 15 7590. Prestige 14 is running a 50Whr battery, and doesn't get all that great battery life from what I am aware of (mostly NoteBookCheck reviews of similar MSI laptops).
    Dell Latitude 7400 (either the 2in1 or the regular one, I don't remember), has a large 7_ Whr battery option, though it is still on an older 14nm CPU and not Ice Lake.
    LG Gram usually has a 72WHr battery, even in the smaller 13 and 14" models. They are spotty with their TB3 availability, since it's usually only offered on specific sub-models. Maybe Ice Lake will change that.
    Best of luck, I was looking at the same, last year. Never found everything I wanted, and just compromised with a big heavy laptop. Well, not really big, but it is heavier than it could be.
    Mr_Mysterious likes this.
  4. JRE84
    JRE84 Notebook Deity
    check out the asus ux zenbook pros that are being sold on B and H.
    decent graphics card
    great battery life
    thin and light
    thunderbolt
    great 1080p screen
    Im not sure if the lenovo t490s would suite you better but check out lenovo.com
  5. Mr_Mysterious
    There are a bunch of zenbooks so which model(s) would you recommend?
    Mr. Mysterious
  6. JRE84
  7. Mr_Mysterious
  8. Vingard
    Vingard Notebook Consultant
    I purchased a Huawei Matebook X Pro before the US ban and I am amazed at the battery life - not to mention the gorgeous panel. I also owned the Zenbook 15 and can vouch for its solid battery life.
  9. jack53
    jack53 Samsung ATIV Book 6 Lover!
    No opinion here....
