New Firmware for Samsung 960 PRO/EVO
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Ultra Male, May 6, 2017.
  1. Ultra Male
    Ultra Male Notebook Nobel Laureate
    So today I noticed that there is a new firmware for both the Samsung 960 PRO and 960 EVO.
    I have 2 Samsung 960 PROs in RAID 0 so obviously I know that installing Samsung Magician to perform the update won't work since Samsung Magician does not recognize SSDs in RAID mode.
    Here is how I updated both drives.
    1) There is a data loss risk so I recommend you backup your stuff (I personally don't but don't say you have not been warned if you lose your data)
    2) Download the firmware ISO for your SSDs (PRO or EVO) from here from the Samsung SSD Firmware Updates for Windows Users: http://www.samsung.com/semiconductor/minisite/ssd/download/tools.html
    3) Insert any flash drive that you may have lying around and format it in FAT32
    4) Download Rufus Portable and run it as admin
    5) Follow the below illustration:
    6) You may be prompted to download additional files by Rufus, allow it to do that and if given a choice to which method you want to burn the ISO to the flash disk, just stick to the default (recommended)
    7) Reboot your computer and enter BIOS
    8) Change your boot mode from RAID to AHCI (just temporarily for the flash process)
    9) While you're still in the BIOS, also change from UEFI to Legacy mode otherwise you won't be able to boot into the flash drive you just created
    10) Save the changes and exit then keep bashing the key which corresponds to the boot menu options on your laptop, Google it if you don't know or refer to your laptop's user manual. For MSI laptops, you need to keep bashing the F11 key to get the boot menu options, for Clevo laptops, keep bashing the F7 key
    11) Once you boot off that USB Flash Drive, hit any key to continue, the ISO updater will scan for the respective Samsung SSD and prompt you to upgrade, press Y then hit enter to continue, then hit Y again to acknowledge the warning that you may lose your data.
    12) If you have multiple Samsung SSDs like I do, you will be prompted to flash the next drive
    13) After the firmware update has been done, you will be prompted to reboot
    14) As soon as you reboot, enter BIOS again
    15) Change the boot from AHCI back to RAID and form Legacy back to UEFI
    16) Save changes and exit
    17) Done! Be brave....be like Phoenix ...... [​IMG]
  2. Mr. Fox
    Nice! Thanks! I will check it out. It will be even easier for me since I run Legacy BIOS with AHCI already.
  3. ellalan
    ellalan Notebook Deity
    Hi Phoenix,
    Could you please confirm that whether I have the latest version, the version currently I have is 2B7QCXE7 and the Samsung iso also the same.
    Vasudev likes this.
  4. Ultra Male
    You have the latest version my friend.
    Vasudev and ellalan like this.
  5. ellalan
    Thank you:)
    Ultra Male likes this.
  6. Mr. Fox
    Mission accomplished. Nothing to be afraid of, guys. Gracias, amigo. :vbthumbsup:
  7. Ultra Male
    Bro, I used to create a backup of my base image with no drivers/software installed in like 55-59 seconds, now the backup completed in 35 seconds after this new firmware!
  8. tilleroftheearth
    Keep these real world 'benchmark scores' coming - this is what is important - not how fast it can theoretically go... :)
    Could you tell us what software you used and platform? Along with the size of the finished BU file?
    Thanks. ;)
    Vasudev and Starlight5 like this.
  9. Ultra Male
    Very true man, synthetic benchmarks may have not even improved other than a slight bump in 4K Random read speed and maybe that was just a margin of error
    I was booted in UEFI on Windows 10, C: partiiton was 20 GB (hiberfil.sys disabled)
    No drivers or software installed. Just Macrium Reflect Home v7
    Compression chosen (none, I don't compress the base image as it's small anyway)
    Image File Size after creation of the image = 9.84GB
    A bit confusing why the image is smaller since I chose no compression, but it is what it is
    Mr. Fox and tilleroftheearth like this.
  10. Papusan
    Mr. Fox likes this.
