New Eluktronics Mech 15 or Max 15? Wich will you choose?
Discussion in 'Other Manufacturers' started by frantona, May 16, 2020.
  1. frantona
    frantona Notebook Enthusiast
    Hi! Im up for the new covert series of Eluktronics! Wondering wich one to choose, if Mech or Max 15!
    Mech 15 (3rd gen) Pros: Battery, speakers, cooling system??
    Max 15 Pros: weight...
    Not sure how different can the battery life be... wich one would you chooes?
    Also, how to connect 3 displays to my laptop? (Im bulding a sim rig and would like to have 3 monitors)
    Thanks!
  2. StormFalcon
    StormFalcon Notebook Consultant
    Well the mech is a lot more expensive, but that battery life really makes a difference. It depends on your use case and how readily available power outlets are. If all you're doing is traveling from a home desk setup to a desk at work, then the battery life probably isn't that important. But, if you travel all over the place or you're a student and your school doesn't have outlets in good spots (or if they're all broken), then go for the mech. If you want big battery and light weight like me, then maybe go for a mag 15.
    As for 3 monitors, depending on the resolution and refresh rate of them, you could potentially get a thunderbolt 3 dock for that.
    Sent from my Pixel 3a using Tapatalk
  3. Terreos
    Terreos Royal Guard
    That’s not true at all. If you spec the Max-15 with the same 2070 super and 240Hz display then they are literally the same price. And when specs are equal I think the Mech-15 blows that Max-15 out of the water. The only reason you’d want the Max-15 is you REALLY need something slim. Or if the OP doesn’t want the latest GPU in his machine, then the Max-15 is cheaper with older specs.
    If the Max-17 didn’t exist I would go with the Mech-15. Better keyboard, better cooling, better port selection, and much larger battery. Hopefully in the future give the Max-15 a bigger battery to make it more worth the money.
  4. StormFalcon
    Oh I completely misremembered the prices then, my bad.
    In that case, if $2000 is within budget, then definitely go for the mech
  5. frantona
    In practical terms, how many hours/min can the mech give me vs. the max? Its hard to decide because I want a thin, light and lasting battery laptop.
  6. StormFalcon
    Well, the max will probably get you around 7 hours of web surfing on battery saver mode, and 2 hours while gaming in balanced, and the mech should be around closer to 4-5 web surfing and 1 gaming.
  7. BrightSmith
    BrightSmith Notebook Evangelist
    Can you give me the Tongfang chassis numbers for the new mech 15 and max 15? Are we talking about GM5MP0Y vs GM5MP0W (rtx 2060 model)?
  8. frantona
    Awsome, thanks a lot for your answer!
    StormFalcon likes this.
