New battery calibration process?
Discussion in 'Panasonic' started by cipiripi84, Feb 6, 2013.
  1. toughasnails
  2. Toughbook
    Read post #8 again.
    1) Yes.. It should help this.
    2) You should only care about the 80% charge limit if you are constantly on AC power. If that is the case... Follow Panasonic's guidelines for battery recalibration and you will be fine. Overall these batteries will take a beating for years. They don't last forever though!
  3. Gear6
    Gear6 Notebook Evangelist
    thanks. I mostly use the laptop on battery, and charge it when it's ~fully discharged, so I should be good without 80% limit.
    But, as it's been 5 months since I started using it, it's time for a recal.
    How long does it usually take (with the battery charged as it is now) ?
    I want to know, to be able to keep it plugged as long as it needs.
  4. toughasnails
    If your battery is in good shape then it's going to take 6-8 hours . My 30 took about 7 hours last time I did it. I always run it at night so when I get up it's all done. It all comes down to how good your battery is.
  5. Toughbook
    I've got several CF-30s right now that took 14+ hours since they have the media bay battery too. But on a single battery... 6-10 hours on mine... A CF-19 should be 5-8 hours total depending on if it needs to be charged before discharge.
  6. Gear6
    it's recalibrating now. it took 1hr to charge from 90% to 100%. now it's dicharging... I estimate ~7hrs (1+3dischage+3charge).
  7. Gear6
    recal completed this morning. I supposedly lost 10% of capacity... a bit disappointed, after 5 months of usage from a new battery used in a proper way (w/ 25 cycles & 220hrs total cf19 runtime).
    Later Edit:
    Before the calibration: 100% reported capacity, drop from 23% to 10% in a few seconds
    After: 90% reported capacity, there's STILL a drop from ~19% to 10% in a few seconds: battery-drop.png see image attached.
  8. cipiripi84
    cipiripi84 Notebook Enthusiast
    Thanks for the all replies.
    I ordered and received a new oem battery (off the ebay). I placed the battery in the slot, its charging for lets say 15-20 mins then Im getting red flashing light?..I thought something was wrong with my charger so i went ahead and ordered oem charger from amazon (old one was IBM)..and again the same story..
    The seller told me its brand new battery never used, but after a couple of minutes charging it ,Im getting flashing red light.
    Any ideas?
    thanks
  9. Gear6
    this doesn't sound too good. the problem with batteries, is that they degrade over time even when stored and not used (especially if it's discharged).
    How old is the battery ? (look for the manufacture date in Panasonic PC Information Viewer, or some other battery info program).
    I remember reading here about this happening (red light a short while after charging is started). It may be that it's not accepting charges anymore (internal resistance too high, etc).
    I'm not 100% sure, but with worn out NiMH cells, the voltage rises quickly to high levels, so the charging circuit stops the charging process, to prevent overheat/fire/etc. Hope that's not the case here.
    Did you charge it with the PC off, or on ? leave it off, plugged in, for a few hours at least, maybe it was deeply discharged, and it may start charging eventually.
    How many cycles does it have (should be zero, or 1-2), and what's the reported Design Capacity and Last Full capacity) - PC Info Viewer
  10. cipiripi84
    In Panasonic PC Info viewer I can't find manafucture date of the battery.
    I tried first with PC off. First couple of minutes it was charging then red blinking light. I tried with PC on and the same thing.
    Interesting thing is, while PC is on red flashing light, I took battery out and put it back in, red flashing light is gone, and after couple of minutes its back.
    I run this program called BatterCare, and its showing total discharge cycles :0, and design capacty and las full capacity I cant find those either in my pc information viewer.
    I apologize for my bad english.
    Have no idea what to do with this red blinking light issue. Its blinking red light even if I take the battery out of the laptop
    EDIT: Battery model : CF- VZSU48
    Total capacity: 60700mWh
    Current capacity: 610 mWh
    Voltage: 5382mv
    Wear level: 0.00%
    Last calibration date: No record
    Calibrations performed: 0
