New Alienware M17X owner with Questions
Discussion in 'Alienware 17 and M17x' started by TIMTA, Oct 20, 2018.
  1. TIMTA
    TIMTA Newbie
    Hi Everyone
    I picked up a used Alienware M17X at Auction and have a few questions.
    I used Dell's website to scan the computer it say's it's a M17X the model number under the battery is P01E
    I see there are R1, R2, R3, R4. I am trying to figure out the correct model before buying parts. I am assuming
    it's just a plain M17X.
    It did not come with a charger so I used a charger from another Dell and it worked for the most part. after reseating the Ram I got the system to boot. The battery won't charge, it's listed as unknown. Assuming this is because the charger is not the original? Otherwise the system works fine.
    The display screen " glass " has a lot of scratches the lcd is fine. Will my model need a new lcd/glass? I watched a video were the bezel was " slid off " and he installed a new one without changing the lcd.
    any advice would be appreciated.
  2. Mastermind5200
    What are the specifications of the laptop? That usually helps for us to find out the model number, although P01E seems to indicate the original M17X R1 with the C2Q/C2D
    The battery is likely long gone, and thats why its not charging
  3. TIMTA
    TIMTA Newbie
    it's a core 2 Duo, 4gig ram, I think the display is " around " 1440x990
    Thanks
  4. Mastermind5200
    Yep, thats the M17X R1
  5. TIMTA
    TIMTA Newbie
    Thank you!. Looking for a battery and can't find any. Looks like I will have to rebuild the one I have. Should be fun getting the case open.
  6. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Please inform us on the process, I too have a M17x R1 with a dead battery, none have been available to purchase since 2014.
  7. TIMTA
    TIMTA Newbie
    My dremel broke so I sacrificed a soldering iron tip, got the battery open. The cells are LGDBB18650 9 of them, can't find any or even a datasheet
    anyone know a equivalent battery?
  8. Reciever
    Reciever D! For Dragon!
    18650 is pretty common actually. I use those on my vaporizer, no idea how diverse it gets in that form factor though...
  9. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    18650 form factor yes, but we need cells that match current and voltage ratings exactly. I could not find anything for what OP has posted, closest name I could find is LGDBB31865, not sure if the ratings are the same as what is needed in M17x R1/R2 cells
    LGDBB31865 is rated at 3.70V x 3 cells would make 11.1V if wired in series, which matches rated spec of the original battery pack voltage rating, but the mAh/Whr is lower. What could possibly be done is to rip a m17x R3/M17x r4 original battery pack and steal the batteries from those, since the voltage is also rated at 11.1V, but 90Whr
    Rengsey R. H. Jr. likes this.
  10. True Debreuil
    True Debreuil Notebook Consultant
