Netgear B/G Wireless Router
Discussion in 'What Notebook Should I Buy?' started by Brian, Jan 3, 2004.
  1. Brian
    Brian Working at 486 Speed NBR Reviewer
    I just bought a new B/G wireless router to replcae my old Netgear B. The setup was very easy with my new G enabled notebook, but my PC with a Netgear B card couldn't find the network. I had to stop and restart the service through My Computer, then it worked fine. So I have one machine on G and another on B and there are no issues. I was able to pick it up for $50 AR and would definitely give it a recommendation. Plus, it's half the size of my old B and doesn't have the massive AC adapter.
    Brian
    Editor in Chief http://www.bargainPDA.com and http://www.SPOTstop.com
