Netbook Advice
Discussion in 'What Notebook Should I Buy?' started by jastek, Jun 2, 2010.
  1. jastek
    jastek Notebook Enthusiast
    I need a netbook for my wife to take to school (she needs something very portable).
    I have never bought a netbook before and from what I can see, most netbooks appear to be very similar, so I need some help on what is the right one.
    1) What is your budget?
    $600
    10-13
    US
    Not a factor
    Must be new
    Using for school
    Must be portable
    No games, but screen quality is important.
    8 hours +
    Not a factor.
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    Windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer?
    The higher the resoluton the better.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen?
    Prefer matte, but not a major factor.
    Build Quality and Design
    Somewhat.
    Probably at Best Buy.
    3 years +
    Notebook Components
    17) How much hard drive space do you need; 80GB to 640GB? Do you want a SSD drive?
    300 - 500
    18) Do you need an optical drive? If yes, a CDRW/DVD-ROM, DVD Burner or Blu-Ray drive?
    External drive is needed.
