Need wifi approx 300 feet from modem
Discussion in 'Networking and Wireless' started by SMOKE_SKULL, Jun 9, 2018.
  1. SMOKE_SKULL
    SMOKE_SKULL Notebook Deity
    Campground situation where modem is located 100 meters from rv i stay in. Its direct line of site with no obstructions. Cannot run ethernet cable due to active road. Is it doable with standard wifi router? I know they make special setups for distance but the cost is not feasable.
  2. downloads
    downloads No, Dee Dee, no! Super Moderator
    Did you consider a directional antenna? Flat panel of parabolic mounted on the outside of your RV would probably be best but maybe an internal one would suffice.
    That's between $20 and $50 depending on if it's an indoor one or not and on the gain.
    Your router would have to have external antennas with RP-SMA connector (it's a standard connector for router antennas in case you're wondering).
    Dennismungai and Aivxtla like this.
  3. KLF
    How fast link do you need? Couple old routers that are dd-wrt or similar compatible, configure them as a wireless bridge and a directional antenna on both. Home made directional antenna like in the video above works but I'd only keep such thing indoors.
