Need to replace my Clevo P150HM...Should I go Mythlogic or Alienware or Other?
Discussion in 'What Notebook Should I Buy?' started by Yauchy, Aug 28, 2017.
  1. Yauchy
    Yauchy Notebook Enthusiast
    General Questions
    1) What is your budget? $1500 - 2500
    2) What size notebook would you prefer? 15.6, worst case 17.3
    3) Where will you buying this notebook? You can select the flag of your country as an indicator. FL, USA
    a. Like: Sager / Clevo, Alienware
    b. Dislike: Asus, MSI
    5) Would you consider laptops that are refurbished/redistributed? Open box at most.
    6) What are the primary tasks will you be performing with this notebook? Laptop solely for gaming
    Very little movement, mostly forever on a lap-pad on the couch.
    ARPGs & MMOs, occasional FPS' or MOBAs
    9) How many hours of battery life do you need? Minimal, moot point for me
    10) Would you prefer to see the notebooks you're considering before purchasing it or buying a notebook on-line without seeing it is OK? I don't need to see it
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc. Windows only
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.) I really want it to be 4K at a minimum
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Matte
    Build Quality and Design
    Nope. I don't even need a backlit keyboard and I like to sticker my machine up.
    15) When are you buying this laptop? As soon as possible
    16) How long do you want this laptop to last? 5+ Years
    Notebook Components
    SSD + 7200 RPM Data Drive or 2 SSDs
    18) Do you need an optical drive? If yes, a DVD Burner, Blu-ray Reader or Blu-Ray Burner? Nope
    My Clevo P150HM of over 6 years is finally painfully dying even playing Path of Exile or Overwatch on lower settings. I want something to last a similar duration and am curious if I should go Mythlogic again or Alienware or otherwise. Heat and future proofing are my concerns, so 4K seems to be a must and I don't need a rig to run Ultra but I'd like to stay high - medium for years to come.
    Currently I have about 1500 saved up and I really don't want to take a credit hit at the moment, so I'd like to stay as low as possible - which is why I'm looking for suggestions beyond Mythlogic / Alienware as well.
    Thanks in advance for any input
    ~Yauchy
  2. sicily428
    sicily428 Donuts!! :)
    clevo p750dm2
    clevo p775dm3
    msi 16L13
    these have a desktop cpu and a mxm gpu
    i7-7700k needs to be delidded
    hidevolution offers delidding of cpus
    Captain_Bobby likes this.
  3. Landspeeder_95
    Landspeeder_95 Notebook Enthusiast
    Search these forums for Mythlogic before pulling the trigger.
  4. Captain_Bobby
    Captain_Bobby Notebook Consultant
  5. Yauchy
    I was actually quite bummed out to learn the bad things Mythlogic has been doing these days...my laptop is going on 7 years old and I've had nothing but good report with them.
    That said I for sure know I want a 1070, 120Hz screen, and something that doesn't burn itself alive. While I'm partial to Sager due to my current laptop's success, I'm open to anything BUT ASUS.
    Thanks for the replies :)
  6. Yauchy
    @Captain_Bobby I see you were praising Mythlogic as of April of last year, has that much changed since then? It seems the threads about them sure have...
