Need Tech help! Frustrated w/ Dell Repair Center and my dang laptop!
Discussion in 'Alienware 18 and M18x' started by misspyt, Jun 13, 2016.
  1. misspyt
    misspyt Notebook Enthusiast
    Alright. Super long story. So, my m18x which is three years old this month was overheating when I played games like Garry's Mod (don't laugh). The temps would go as high as 96 C, and I would have occasional moments when the laptop's display would turn black. The keyboard would stay lit up, but the computer had stopped working, so I'd restart it. No problem. Also, the battery was going out, so I needed a replacement. Well I needed my laptop for school, so decided it would be best to keep it until I could finish some important work. Finally, I sent it to the Dell Repair Center (my warranty goes out on July 29). They replaced the battery, heatsink and video card.
    The computer came back. Everything seemed fine, until I opened up Garry's Mod. Almost 10-15 minutes into the game, the computer shut off. After that, I couldn't even open a game....Heck, I could barely log into Windows. Soooooooo called Dell, and we realized that disabling the video adapter helped, so the tech guy told me to keep it like that until they could do something. Safe mode or no safe mode, video adapter disabled or not, absolutely no video games played after Garry’s Mod crashed, and STILL the display would go off.
    Here’s a walkthrough in case you’re confused.
    Turn on computer. Put in password to Windows. Windows comes up with all my icons. Open my browser to read some tech stuff to help the issue. Screen turns black within minutes of restarting. Keyboard still lit with colors. Sound is muffled in the background (if I was listening to something). Keyboard and annoying muffled sound continues until I press the Alienhead power button to turn it off. Sometimes I have to hold it down to turn it off, and others, I just tap it. AND REPEAT
    Computer was sent to Dell again… Took them a month to repair it. I waited patiently. Same thing…heatsink and video card replaced. I was sooo excited to have it back. It was doing so well. I turned it on and left it alone for a whole day. Decided I should play Garry’s Mod. It lasted maybe an hour…or hour and 30 mins (I really like G Mod). I did notice that when a new round would start, this REALLY LOUD buzzing sound would happen for a few seconds then go away. This sound thing happened twice. Anyways, while playing, I get the pixelated screen in the post…………………Restart the computer. Put my password into Windows…Turned on Steam…Then got a white screen. It’s extremely frustrating to have the same problem even though my computer was given to them for soooo long and TWICE!
    Thursday, the computer ran a CHKDSK (because I read one of my event viewer logs stating failure. I will post some of those if I have them. Tried to do a system restore as well. Have pics for that.
    I don’t know if this is a way to get me to extend my warranty or simply, that they don’t know what is going on. If anyone can help, I would appreciate it.
    Is my computer just done for? :/
    Configuration
    Alienware M18X R2
    18.4 inch (467.36 mm) WLED WideFHD (1080p) display (1920 X 1 080)
    Alienware M18x 240W A/C Adapter
    Windows 7
    750GB 7200RPM SATA 3Gb/s
    96WHr 12-Cell Primary Battery
    Slot-Loading Dual Layer DVD Burner (DVD+-RW, CD-RW)
    2GB GDDR5 NVIDIA GeForce GTX 6 75M
    Intel 2230 Wireless-N
    3rd Generation Intel Core i7-3 630QM (6MB Cache, up to 3.4GHz w/ Turbo Boost 2.0)
    12GB Dual Channel DDR3 at 1600 MHz
    64GB mSATA caching SSD
  2. maxslo
    maxslo undefined
    IMO, the GPU's you are getting as replacements are refurbs, and are literally lasting that long before crashing... The FS is corrupted because you are forcefully shutting it down having really no other choice when the GPU crashes...
  3. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    675M is toast. Need something more reliable like 680M, 780M, 8970M
  4. GodlikeRU
    GodlikeRU Notebook Deity
    GPU is dead. @maxslo is right. @Raidriar is also right.
    Btw Nice wallpaper m8 ;)
  5. misspyt
    Crap what the fudge should I do? Lol I'm not techy, so you'll have to spell some things out for me.
    Lol and thanks @GodlikeRU
    So many questions I want to ask lol
  6. Rengsey R. H. Jr.
    Here is a video of the tear down by @Mr. Fox of your laptop. Just follow instructions. It's a repaste job but it's the same way to get to the gpu.
  7. maxslo
    maxslo undefined
    I think you should push them to swap a card to a different one since you've got 2 bad ones already.... i'm thinking about the 680M, or atleast 670M, less power, but wont fail nearly as much as the cancer 675M
    deadsmiley likes this.
  8. GodlikeRU
    675M is rebranded 580M that dies very often.
  9. maxslo
    maxslo undefined
    Oops i meant the 670M :)
    eerm, nevermind, i did write 670M....
  10. Mobius 1
    675m is 580
    670m s 570
    the mx is kepler, iirc
