Need original Clevo DVD drivers for P170EM
Discussion in 'Sager and Clevo' started by pastapvz, Oct 29, 2014.
  1. pastapvz
    pastapvz Notebook Geek
    Hi guys,
    Can anyone send me the original driver for AMD 7970M that came with the DVD, only want the driver that came with the DVD because other AMD 7970M drivers never worked on my machine (even the ones that are available on Clevo site or Sage), my DVD with the drivers failed me, so I'm kind of stucked.
    Just upgraded EC and also Bios to see if it changed anything, but it remains the same.
    Thanks
  2. MrDJ
    MrDJ Notebook Nobel Laureate
    newer drivers should work. if not try a safe mode install.
    you could follow some of my link below but change everything that says nvidia to AMD.
  3. pastapvz
    Thanks for the reply, newer drivers never worked for me, and I tried to install many times, even with a fresh windows instalation( no previous drivers) they didn't worked and I can't understand why, but I will try your guide to update when I get home and will give you my feedback.
  4. pastapvz
    Well it won't really be an update since I don't have the original drivers that came with the dvd :) but I will read your guide and will try it out :)
    In the meatime if anyone has the original AMD 7970M that came with the DVD I would appreciate :p
    Thanks
  5. Altered Phoenix
    Altered Phoenix Notebook Evangelist
    Will one of these work?
    CLEVO Driver Download
    Edit: Sorry, just re-read your post. I guess you already tried these
  6. MrDJ
    just got my disc out but for some reason wont open on either of my clevo laptops so sorry but cant upload the driver for you :(
    who was your supplier? might be worth contacting their support to see if they can find you the original driver.
  7. pastapvz
    Thanks for the reply people, just followed your guide and tried the drivers that Hutsady@XoticPC linked and it worked :), those are from Sager 24-May-12, tried the same method for the latest catalyst and I can't get it to work, maybe I'm missing something!!
    Anyway thanks for the help, if you have any suggestions I'm all ears :)
  8. MrDJ
    i know nothing about amd drivers so dont know what else to suggest.
  9. pastapvz
    Your post helped :) thanks ;)
  10. MrDJ
    :thumbsup: your welcome
