Need my trunk to rattle less?
Discussion in 'Motorized Vehicles' started by Harper2.0, Mar 10, 2009.
  1. Harper2.0
    Harper2.0 Back from the dead?
    So I've got a semi-dilemma. I have a Pioneer deh-p 7700 CD player in my car, along with the stock speakers that came with it (2005 Honda Civic), a 725rms watt/1000max power Kenwood amp + 2 12" Lightning Audio (1500watt) subwoofers in a ported box. I wanted to know what would be the best approach to eliminate the rattling and get cleaner bass from my system. One of my friends recommended Dynamatt(which I think is an excellent idea), and I've thought of getting a custom box made for the subs to maximize the bass, but I though I'd ask the Sound experts on NBR before spending any money.
    What do you guys/gals think?
  2. Clutch
    Clutch cute and cuddly boys
    If the trunk is rattling rubber around the seals would help, or it could be caused by the cones hitting the grill.
  3. nizzy1115
    nizzy1115 Notebook Prophet
    YOu really have to figure out what parts are touching each other to make it rattle, and put rubber between them. Dynamat will not fix this issue.
    A good way to do this would be to get a constant low frequency playing on a loop. That way you could hear the rattles better
  4. Harper2.0
    I belive it is the trunk lid itself(the part of the lid that touches the body of the car, if that makes any sense).
  5. nizzy1115
    There are many parts that would touch i think, plus there are more mechanisms in the trunk as well for it to open and close.
    Whats weird is my car i can hear the rattles outside the car, but not inside.
  6. Tippey764
    Tippey764 Notebook Deity
    Sounds like a ricer to me.
  7. stewie
    stewie What the deuce?
    Get a Trunk Monkey.
    <object width='425' height='344'><param name="movie" value="http://www.youtube.com/v/8avOiTUcD4Y&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/8avOiTUcD4Y&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width='425' height='344'></embed></object>
  8. The Fire Snake
    The Fire Snake Notebook Virtuoso
    If it is the trunk lid Dynamat Extreme is awesome. I have a lot of that. It is pricey but very nice.
  9. Harper2.0
    If by ricer you mean stock Civic with a Pioneer deck and some subs, then guilty as charged :p
  10. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    Dynamat if first step, not only will it significantly reduce the rattle it will make everything sound better in the car. I wont go into the long explanation why but I used to do car audio competitions and build/design systems.
    After you have a good install of that stuff, track down any remaining vibrations and tighten down those parts or add a vibration dampener material.
