Need light gaming 2-in-1
Discussion in 'What Notebook Should I Buy?' started by npaladin2000, Jul 12, 2018.
  1. npaladin2000
    npaladin2000 LOAD "*",8,1
    I'll just start with a summary, I'm looking for a lightweight 2 in 1 that can handle light gaming, nothing heavier than FF13 or Starcraft 2 (low settings is fine). I can bring my own OS and do my own modifications if needed, so refurbs are OK.
    General Questions
    1) What is your budget?
    Trying to keep it under $1000 US
    c. Thin and Light; 13" - 14" screen
    USA
    Nope
    Yep
    Remote desktop, web browsing, emulation, light gaming, systems management
    I carry my laptop with me every day
    Yeah, but older games, Starcraft 2, FF13 would be the most recent ones
    Need 4 hours. Would like more if possible
    Online is fine
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows 7 or 10 preferred for this
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    I prefer a FHD resolution, either a 16:10 or 3:2 screen
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Glossy
    Build Quality and Design
    No
    WHen I find it
    at least a year, preferably two
    Notebook Components
    At least 256 GB, 512 would be better, but I have a spare 512 GB SSD around if needed
    Nope
  2. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    @npaladin2000 15" Yoga 720 with GTX 1050 or older 14" Thinkpad Yoga 460 / P40 Yoga with 940MX or its quadro counterpart are pretty solid options and within your budget. The former obviously performs much better, with quad-core CPU and mid-range graphics, while the latter offers superior typing experience and battery life.
  3. don_svetlio
    Acer Nitro 5 Spin is your best bet imo.
    Mastermind5200 likes this.
  4. npaladin2000
    I appreciate the suggestions, but 15 inch is too big. 14 inch is the max I'm looking for. I'll check out the 14 inch Thinkpad.
  5. Mastermind5200
    Honestly, its not thay big. You'll have a much better time with anyways
    don_svetlio likes this.
  6. don_svetlio
    The difference in size is small but the difference in performance is big since it's hard to cool a decent GPU in a 14" 2-in-1
  7. Mastermind5200
    Exactly!
  8. 9ac3
    9ac3 Notebook Consultant
    For light gaming, I think something with a MX150 would do the job. Not a 2-in-1, but I would look at Lenovo 720s. It has both the 13.3" and 14" versions. The display is great and it also comes with a TB 3.
  9. npaladin2000
    I have a 15inch Ryzen setup. It's too big and too heavy to carry around, I end up leaving it at home.
  10. don_svetlio
    Then you'll have to contend with lower performance.
