Need help with the 1060 in my p370sm3!
Discussion in 'Sager and Clevo' started by Dendrit3, Jun 12, 2018.
  1. Dendrit3
    Dendrit3 Notebook Consultant
    Hello good folks!
    I just upgraded my laptop with an MSI gtx 1060, and all went well and successfully booted. But I have stuttering and gpu not recognized. I did a DDU cleaned nvidia drivers, have no other drivers installed atm.
    Here is the picture of my BIOS, Prema v2.
    Here is a pic of my bios
    Edit: on device manage the display adaptors shows "microsoft basic display adapter"
    How do I fix this?
    thanks!
  2. Prema
    Prema Your Freedom, Your Choice
  3. Dendrit3
    Thanks prema, works great now! My gtx 1060 is showing up :) :vbthumbsup:
    Btw in your last step the NVIDIA CONTROL PANEL -> CHANGE RESOLUTION -> “USE NVIDIA COLOR SETTINGS” is not changing to nvidia colour settings, it goes back to default. This wasn't the case with my last gpu. Can I fix this?
    I googled it and there is a way to change the Output dynamic range from limited to full but I dont have that.
    edit: one more thing it still shows as unknown in BIOS. Maybe thats normal.
  4. Dendrit3
    I have another issue, I get really bad temperatures, 90+ degrees on idle. :( Got the 780m heatsink.
  5. Danishblunt
    Danishblunt Guest
    The GPU die has a lesser height, hence it needs a shim soldered to your heatsink otherwise you will suffer from high temperatures.
    Unknown in BIOS is normal, the GPU is not detected in premas BIOS as a known GPU.
    KY_BULLET likes this.
  6. Dendrit3
    Yeah looks like it as I just checked, as there is a small space between the gpu die and the heatsink, but how much of a shim should I get in mm?
    also would bad thermal pad layout cause this heat issue?
  7. Danishblunt
    Danishblunt Guest
    I think 1mm - 1.5mm should do the trick.
  8. Dendrit3
    Allright, I will try with 1mm and what is a good temp on idle? just so I know if it's working.
  9. Dendrit3
    you think 30x30x1mm is good or is it too big?
  10. Prema
    The nv color problem is a 1803 issue...
    Not detecting and supporting new GPUs without driver Mod is normal for the public Mods.
    Dendrit3 and KY_BULLET like this.
